Rack and Pinion aka steering rack replacement
Discussion in 'Gen 2 Prius Technical Discussion' started by NortTexSalv04Prius, May 9, 2018.
  1. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    116
    Okay
    I have discovered the following issue on my 2004 Toyota Prius . . . the RACK and PINION are toast , done, worn out....
    The noise I can created just by turning steering wheel with vehicle powered on and complete power down is not a pleasant sound.... Not that my hearing is highly refined however I can actually hear the metal on metal movement and worn somewhat popping sound of the individual metal cog contacting the rack as I turn steer wheel. A unsettle noise which makes one (that's me) realize that will require some time labor, and replacement part ….
    Does anyone first hand have knowledge about removal process and more specific once you have remove all mounting bolts, outer tie rods, loosen and remove steer joint spline connection,
    I am making the assumption that the rack and pinion will have clearance out of the wheel wells at some desired time
    Sezy likes this.
  2. NortTexSalv04Prius
    915
    116
    Update
    FYI
    Okay removal of steering rack is relative straight forward(no wire harness to disconnect yet)
    center vehicle front tires straight
    remove/chock
    lock down steering wheel/chock
    loosen remove outer tie rod bolts L/R
    loosen strut brace vertical tie rod thingy
    remove steer u joint, hardware, boot, four rack bolts etc
    current pricing range for steering rack
    Ebay $780 (high) to $119 (low) reman
    Ebay used $300 to $80
    carparts.com $398 reman
    summit race $139 reman
    rockauto $140 reman
    LHK keystone $50 used
    This takes me to following issues
    Really do not like used parts
    do like reman because there is some display or appearance of business warranty
    have had better experience with A1 cardone than dorman however both have sold out to china mfg.
    Sezy likes this.
  3. Sezy
    Sezy Active Member
    443
    231
    37
    Saint Charles, Missouri
    2020 Prius Prime
    Take it this fixed your issue? Just replaced my steering column down the the intermittent shaft and still have some wheel play. Was thinking if it bugs me still after trying different tires I'd replace the lower rack and pinion.
