radar cruise control problems
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by AIRDRIVERUSA, Dec 14, 2017.
  1. AIRDRIVERUSA
    AIRDRIVERUSA New Member
    Nashville, TN
    Hello all...thanks in advance for your help...i am a new 2010 prius owner with a prius v...was utilizing radar cruise control last night on a small trip...was working fine until i switched to radar mode instead of regular mode. so i turned cruise control off...then i turned it back on because radar cruise control is default mode...when i went to set speed, prius slammed on brakes as if it was seeing something in front of me when there was not. immediately after setting cruise control it would brake heavily...i then tried lane keep assist...as you know, lane keep assist has two automatic modes: one mode only works with the radar cruise control working and the other mode should work without cruise control on...well neither mode works either. DOES ANYONE ON HERE HAVE A CLUE WHY THIS IS HAPPENING??? HAS THIS EVER HAPPENED TO ANYONE ELSE??? Any help with this would be greatly appreciated!
  2. JC91006
    16,876
    8,619
    Can you take a picture of the front Toyota emblem of your car? If the car has been in a front end accident and the wrong emblem is installed, it would do that.
    1 front end accident
    2 wrong emblem
    2 possible causes
  3. AIRDRIVERUSA
    Nashville, TN
    Hey. Thanks for the reply. I do not know how to put a pic on here. It is a one owner car...it has no damage history and it just started doing it. I did get the car detailed...could they have done something with it then? Does the camera up near the rear view mirror have anything to do with this system? Thanks again
  4. AIRDRIVERUSA
    Nashville, TN
    Figured it out
  5. kimusabi
    kimusabi New Member
    2017 Prius v wagon
    Yes, the camera behind the rear view mirror is part of the assisted driving system. Make sure there is nothing obstructing it.
  6. Tideland Prius
    16,632
    Well were you following anyone when you set the DRCC? It has 3 following distances (and the default is LONG) so if you were following someone closely, it will slow down to increase that distance. You can change the distance setting with the silver buttons on the steering wheel (next to the LKA button).
