Radiator Coolant Bleed Valve Leaking, Valve Replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by chuckPris, Sep 2, 2021.
  1. chuckPris
    chuckPris New Member
    Portland
    Help!
    I'm trying to bleed my radiator coolant system using a tube and idling the car. The problem is that the bleeder valve is leaking when I loosen it to burp the air. The side connector where I attach my tube is solid, but the coolant seems leaks out the top seam.
    I can't find a replacement part number, nor tutorials on replacing the part. Has anyone gone through this before? Screenshot_20210902-190946.png
  2. chuckPris
    Portland
    I should mention, this leak is substantial and lot of fluid is lost.
  3. JC91006
    16,480
    8,397
    can you tighten it and stop the leak?
  4. ChapmanF
    15,569
    In the copy of the repair manual I'm looking at, that valve is never opened while the engine or CHRS pump is running.
    It is opened in step e, to allow air escape while pouring coolant in, then closed in step g before running the CHRS pump active test.
    It is then reopened in step n, after the CHRS pumping is done, to allow air escape while topping the coolant off. Then it's closed again in step p before idling the engine up to operating temperature.
    So it seems in Toyota's procedures, that valve is never going to be open while the coolant is circulating or under pressure. So they probably just don't care much that it might be leaky if opened under those conditions.
    Fred_H likes this.
