Radiator drain spigot: Very difficult
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by xliderider, Aug 29, 2021.
  1. ChapmanF
    19,047
    The repair manual instructions do specify that the cap is on, so the system can come to normal temperature and pressure. I don't pretend to be an expert on why, but it could make sense that at operating pressure, the same amount of trapped air occupies bubbles of smaller volume, and may be carried more easily through the burp hoses back to the bottle.
    I usually have my ScanGauge connected, so I can see the coolant temperature; it gives me something to watch while I am sitting there thinking "are we there yet?". In cooler weather, it might seem to plateau somewhere shy of the 95 ℃ trigger point for the fans. If I see that, I'm not completely above pushing the go pedal slightly to help the process along.
    Mendel Leisk and xliderider like this.
  2. Rocky Mountain Priusman
    Rocky Mountain Priusman Active Member
    224
    112
    Canmore, Alberta, Canada
    I had the same problem - was scared I'd break it. Ended up finally getting it unstuck by grabbing it with a pair of needle-nose pliers and twisting very hard. I also soaked it in a lot of WD-40, not sure if that helped or hurt.
  3. Rocky Mountain Priusman
    224
    112
    Yes that is what it looks like. I followed the nuts about bolts video for my coolant drain and refill and it went textbook perfect the first time.
  4. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    What year is your Prius? My 2011 doesn't have the bleed valve.
  5. ChapmanF
    19,047
    As the stopcock is plastic and not subject to rust, I don't think WD-40 does much for it. I would be a little concerned about WD-40 having some possible chemical incompatibility with it, embrittling it or something.
  6. Mendel Leisk
    42,368
    Silicone spray maybe?
  7. xliderider
    8,140
    3,280
    Honolulu, HI
    Or grease, like the silicone brake slide pin lube.
    Well, of course that would be AFTER you get it out. For next time.
    #27 xliderider, Sep 5, 2021
  8. ChapmanF
    19,047
    This sounds like the same kind of thing that happens with the oil filter cap.This stopcock seals with an O ring. There's no need to even have it tight at all, beyond turned all the way in. I found it awkward to open by hand, just because my hand doesn't bend that way, not because it needed much force to open.
    Unless the last person who tightened it thought it had to be übertorqued for some reason.
  9. xliderider
    8,140
    3,280
    Honolulu, HI
    I wonder if all the thermal cycles of heating/cooling, expanding/contracting of the materials surrounding the plugs makes it very snug over time?
  10. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    Isn't there just a lower radiator hose we can disconnect to drain the coolant?
    I watched a mechanic's YouTube channel yesterday, and he said he never uses the radiator stopcock. He always disconnects the hose because on older vehicles, the stopcocks get fragile and break. For me, I never had a problem with the stopcock, but if you have difficulty with it, perhaps it's less trouble to simply disconnect the lower radiator hose.
  11. xliderider
    8,140
    3,280
    Honolulu, HI
    Moved on to installing an OCC in our 2014 Corolla.
    Interesting, even though the Corolla and the Prius share similar 1.8L engines, the Corolla's intake manifold doesn't seem to have separate EGR passages in each intake outlet port like the Prius. I'm not sure if the Corolla even has EGR gases going to the intake. There's no cooler and the intake ports at 60k have no nasty soot, just a light coating of oil in the intake manifold and intake ports.
    The PCV valve is in the same horizontal location on the engine block, but the PCV hose is about twice as long, and the diameter of the inlet and outlet sides are the same. The Corolla's PCV hose has a foam heat insulation and a fiberglass heat shield sleeve around it as well. The intake was dripping oil when I took it off, but there's no obvious place for the oil to pool because the throttle body is mounted higher up on the intake manifold and pointed down about 30 degrees.
    I'm going to relocate the PCV valve to the OCC outlet, so that will probably keep a lot of oil out of the intake. 20210910_115744.jpeg 20210910_120301.jpeg 20210910_120243.jpeg
    Raytheeagle likes this.
