Radiator/Grill cover
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by syscon, Oct 2, 2012.
  1. syscon
    syscon Member
    329
    42
    Edm. Alberta
    Winter is coming :-/
    What do you folks use to cover up the front grill and/or radiator?
    Access to cover up the front radiator with some kind of cardboard is not good, besides I'm not sure if covering the radiator with cardboard is a good idea as this might disrupt the cooling if needed.
    I think better option is to buy in local hardware store some material to seal just the lower and upper portion of the front air grill.
    (In Alberta we get -20C to -30C (-4F to -22F) on a regular basis).
  2. CLUBGUY
    CLUBGUY Member
    293
    49
    Cincinnati
    2010 Prius Grill Blocking strategy | PriusChat
    May help you....
  3. JACoH
    JACoH Enjoying the mileage
    193
    40
    Oregon
    I found a piece of flat rubber about 6" x 30" at a Home Improvement store, not sure what it was for. Cut it to fit BEHIND the lower front grill and attached with zip ties, works fine, not as ugly as the pipe insulation put on the front. It might have been for a roof gutter or something like that.
