Radiator is cold...
Discussion in 'Gen 2 Prius Main Forum' started by Brian Thompson, Jan 5, 2013.
  1. Brian Thompson
    Brian Thompson New Member
    Vermont
    I am having heat issues with my 2004 Prius. Recently it has been difficult for the defroster to keep the windshield clear and the heat output is clearly not normal. It's chilly here in Vermont so having heater is important. I have been doing some reading in this forum and have gained some insight into how the heating system works.
    One observation I notice is that the radiator does not seem to get hot at all. If I open the cap on clear overfill tank under the hood it appears to be full. In fact the coolant seems to be circulating through this tank. If I dunk my finger into the fluid it is only warm. There is a warning about not opening when hot but it is not hot so I can open it.
    As I sit in the car I can hear liquid circulating through in the dash board area. When i change heater setting to enable different vents and defrost each change produces sounds that would make me believe the mechanical things are working ok. It's just not very warm.....
    Any ideas on what could be are appreciated and Thanks in advance.
  2. Britprius
    Britprius Senior Member
    5,194
    1,924
    Herefordshire England
    Which tank are you checking, is it the one at the very front of the car or the one between the engine and inverter box.
  3. Joe 26
    Joe 26 Member
    242
    42
    Columbus, Ohio
    Have you had any coolant service done recently? It is not normal to hear any bubbling or coolant circulating through the dashboard, as you state. There could be air in the system due to a leak (look for pink crust, especially at the water pump)or improper bleeding. Absent that, the thermostat may be stuck open.
    Ajourney101 likes this.
  4. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    ...I believe the sound of liquid gurgling is a symptom of having air trapped in your system. I keep wondering if I have air in there too, even though as you say the appearance is full. I am not the expert but you may want to run the car a while with the cap off and see if level fluctuates. In any case, getting air pocket in your antifreeze is common Gen2 Prius issue.
  5. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    You also need to check that the thermostat is working just as in all other cars.
    JeffD
    Ajourney101 and xs650 like this.
  6. Patrick Wong
    18,210
    6,526
    You have air in the engine coolant system. Was the coolant replaced at some point in the past?
    1) Remove the large black plastic cover over the radiator (held on with six plastic fasteners) for access to the radiator cap. To remove a fastener, rotate it with a Phillips-head screwdriver while exerting upwards pressure on the cover. The fastener will pop out of the hole. Remove the cap and see where the fluid level is.
    2) If the fluid level is low, top off with Toyota Super Long Life Coolant. Do not use a lesser substitute. Replace the radiator cap.
    3) Once the fluid level is correct, start the Prius. Turn on the heater, set temp to MAX HEAT and the ventilation fan to max speed. Rev up the engine repeatedly to 3,000 RPM or more - may take 5-10 minutes or more, while listening to the air bubbling in the heater core. Keep revving up the engine until you no longer hear bubbling.
    4) Turn off the Prius. Feel the radiator cap. If it is not very hot, open the cap, check the radiator fluid level and replenish to top of radiator neck as needed. Otherwise wait for the cap to cool down, then check the fluid level and fill. Replace the black plastic cover and you are done.
  7. Brian Thompson
    Vermont
  8. Brian Thompson
    Vermont
    The one between the engine and the inverter box.
  9. Brian Thompson
    Vermont
  10. Britprius
    5,194
    1,924
    That is not the tank for the engine that is the coolant for the inverter and transmission. The tank you want is under the black plastic cover right at the front of the car as explained in the above posts.
  11. Brian Thompson
    Vermont
    I have not had the coolant serviced recently. It was serviced at around 100k miles and I am at 193k now. Need to go check the level in the radiator now based on a reply from Mr. Wong
  12. Britprius
    5,194
    1,924
    Since you are well passed the 100,000 mile marker the coolant should be replaced every 50,000 miles with the correct coolant Toyota SLLC. It is likely however that the engine coolant pump is leaking and will need to be changed changing the fluid at the same time. However the fluid will need topping up now.
  13. Brian Thompson
    Vermont
  14. Brian Thompson
    Vermont
    Mr. Wong,
    Thanks for your detailed instructions on how to proceed. I was able to remove the black plastic cover and get to the filler cap for the radiator. Since the radiator filler pipe is plastic and has a 90 degree bend looking in the neck for fluid level level showed no fluid. I measured 24 oz of fluid and started to add it in. It was slow going and I had to wait a few seconds between each pour but it took about 20 oz before it was full.
    I then followed your step three for getting the fluid circulating properly again. I can feel that temperature has improved since adding the fluid. I will iterate again on the "top off" and see how it works tomorrow.
    Thanks for your advice!
  15. Brian Thompson
    Vermont
  16. Brian Thompson
    Vermont
    Topping up the fluid level has made a difference. I added sbout 20 oz of fluid and the heat output is better. more like it use to be. I plan to have the coolant system filled properly at dealer next week. Thank you for your comments and insights.
  17. Britprius
    5,194
    1,924
    Please check the engine water pump for leaks as topping up will need to be done often otherwise and if the pump is leaking it can only be a matter of time before it's bearing fails completely maybe stranding you somewhere.
    A leak at the pump usually shows up as a red crusty deposit inside the water pump pulley and sometimes as a line on the underside of the hood.
    John (Britprius).
    Ajourney101 and PriusGuy32 like this.
  18. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    I am thinking there are two filler caps, one for the radiator itself, which when open you are looking straight into the radiator fluid level, and the plastic overflow pot, which has the bends. The most direct way to refill (at least what I do) is pour straight into the radiator until full to the top. Then I also fill the overflow pot to make sure there is some extra if needed. I do not take the black plastic off, I just reach under there to unscrew the cap. Loosen one screw maybe.
  19. sorka
    sorka Active Member
    1,034
    199
    Merced, CA
    2019 Prius
    You were probably filling the reservoir tank rather than the radiator. If it's really cold, like in the twenties, the prius thermostat will never open and hot water will never circulate through the radiator. The only time water circulates through the radiator is when the thermostat opens which only happens when the water in the core, behind the thermostat gets hot enough.
    Secondly, the heater has *nothing* to do with defrosting your windshield. Your AC is what does that, so if your defroster is no longer working, then your AC is shot. You can keep the temp output to 65 (minimum) and if your defroster is working, it will clear the windshield in seconds.
  20. jpadc
    jpadc Type before I think too often
    343
    34
    Indianapolis and Northern Wisconsin
    2017 Prius Alpha
    Seriously?
