Radio Fuse
Discussion in 'Prius c Audio and Electronics' started by Francisco Castro, Apr 26, 2025.
  1. Francisco Castro
    Francisco Castro New Member
    Miami
    Morning. I bought a Prius C 2013. The radio power supply remains turned on all time, so I tried to disconnect for battery consumption, but now the radio doesn't turns on, but the power supply is on.
    Which one are the radio fuse?
    Thx
  2. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    The radio is powered by 5A ACC, 15A DOME, 10A GAUGE fuses. But the thing is that the named faulty fuses will cause other problems in other systems. Maybe your radio is simply not configured? If there are any signs that it is working - light indication on the panel, tonal sounds from the speakers?
