Radio not working
Discussion in 'Gen 2 Prius Audio and Electronics' started by Tynyyn, Feb 5, 2020.
  1. Tynyyn
    Tynyyn Member
    109
    30
    Bella Vista Arkansas
    My original radio works, i.e. it turns on and off, yet the static is impossible to listen to any radio stations. I'm wondering if anybody might have a fix or at least where I turn to find an answer. Could it be a mis-connected antenna wire, poor grounding, or simply my radio is dying? Can you toss me a bone?
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Yes.
    Could be any of the above.
    An after-market stereo shop might be able to help.....at a reasonable cost.
  3. dolj
    dolj Senior Member
    8,631
    4,385
    Wellington, New Zealand
    Another possibility is water has leaked into the electronics in the base of the antenna. Also, you would want to check for continuity in the wire from the antenna base back to the back of the head unit.
