radio on time while car off
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by SJ PiP, Dec 1, 2012.
  1. SJ PiP
    SJ PiP Member
    190
    35
    so i was listening to the radio in Acc mode, while waiting for someone, and the radio turned off automatically after ~15min with a warning message. (i guess dvd player would also do the same)
    in the future, i need to actually start the car to listen longer right?
    52,883
    yes, it only uses the 12v and you don't want to deplete it.
    SJ PiP likes this.
  3. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    Why use ACC mode?
    Sitting there in Normal mode won't use any additional energy.
  4. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    You when you have a fully charged EV battery you can use your radio in "READY" mode and you won't get that message
  5. SJ PiP
    SJ PiP Member
    190
    35
    i didn't have full EV charge. if i did have a full charge, could i watch a 2hr dvd out of it? a very expensive dvd player!!
  6. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    You would be able to monitor your battery level by viewing EV. it will go down in miles while connected to your DVD
    srzbae likes this.
  7. lensovet
    2,615
    496
    Burlington, NJ
    I do not know about that. I've sat in the car in ready mode and the miles do drop, albeit slowly. I'm sure keeping everything energized and ready to go does result in some additional draws.
  8. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Yeah, I have a ScangaugeII which has a battery voltage reading, when I turn off my car the ScangaugeII stays on for a few seconds and shows me the actual 12 volt battery voltage (12.9 volts) when in READY mode the battery voltage reads 14.9 volts
    lensovet likes this.
  9. 3PriusMike
    3,101
    2,421
    Silicon Valley
    Yes, but that is not telling you how much current the car uses when sitting idle in Ready mode vs in ACC. The difference in voltage is based on how the car (designers) chose to float the 12v battery to be continually recharged from the traction.
    More than most people want to know: A single device, or battery will read a lower voltage under a higher load. The slope of this curve is part of each specific battery design. But when there are two or more devices (batteries, battery+generator, etc) the voltage reading is based mostly on a controller setpoint in the system, which also has some designed slope to it, but it isn't comparable to the single device/battery load-voltage curve.
    Mike
  10. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I also have Xgauge of my battery amps too.
  11. 3PriusMike
    3,101
    2,421
    Silicon Valley
    So what is the load in Ready vs ACC?
    Mike
  12. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    dono, haven't compared the two yet
  13. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    ok, went out to check, ScangaugeII doesn't work in ACC mode
    3PriusMike likes this.
  14. El Dobro
    El Dobro A Member
    7,106
    3,282
    IIRC, you can get voltages on GenII if you put the car in diag mode. Correct? If so, does anyone know if the PIP can do this?
