Radio reception signal
Discussion in 'Gen 3 Prius Audio and Electronics' started by MikeHof, Jul 8, 2012.
  1. MikeHof
    MikeHof New Member
    Columbia, MO
    I've seen post where people complain about the factory head unit's radio signal not being very strong. Today while driving around on the back roads the signal faded in and out quite a bit. I don't remember it happening before like that. I was curious if a Pioneer head unit would have the same issue due to using the same antenna or if it's just the factory head unit causing the bad reception.
  2. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    It all depends on how much Power the Station is running, how close you are to the transmitting antenna, what kind of antenna you have, whip, shark fin, coat hanger! If it's a hilly location, that does not help either. A good test is get a friend of yours drive you on a route you know you have reception problems. If your friends car acts OK, then your HU is not as sensitive as your friends radio! At that point try to convince the Service Dept the HU FM is defective, try to get it replaced. Or you could just gut the stereo and start over!
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I installed a Pioneer HU (DVD4100) and it made very little difference in reception. Just the nature of the setup in the vehicle. Have a 11 Corolla and the reception is just as bad in it. :(
  4. Big Steve
    Big Steve ramblin wreck
    402
    39
    Richmond VA
    Here in Richmond VA, the Prius has much better reception than our 2003 Subaru Outback and better than our old 1997 Camry.
  5. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    My 2010 Camry SE gets much better reception than the 2011 Prius with JBL premium sound. The Camry has an OEM sharkfin style antenna too, whereas the Prius has the standard stubby whip antenna.
  6. Big Steve
    402
    39
    Richmond VA
    My older cars have/had neither. Antenna in the glass.
