Radio Volume knob overshoots !
Discussion in 'Gen 3 Prius Technical Discussion' started by PriusNeckBeard, Jun 11, 2017.
  1. PriusNeckBeard
    PriusNeckBeard Active Member
    376
    211
    Cincinnati
    The round, radio "PWR VOL" knob doesn't work well. Crazy stuff.
    I'll try to turn it down....but this will sometimes turn it louder ! Lol.
    Or it will change by some tiny amount.
    If I do manage to get it to go down(or up, if I'm going that way), it will overshoot by a lot.
    I finally came up with:
    Use the steering wheel.
    Still, I'm curious...what's up with the darn volume knob?
    52,904
    i don't recall hearing this one before.
  3. Malosos
    Malosos Member
    117
    33
    Los Angeles
    The buttons on my stock stereo only work half the time...I'll be upgrading to an aftermarket stereo in the near future.
  4. PriusNeckBeard
    376
    211
    Cincinnati
    Well, if I just try to rotate the volume knob, I guess it's slipping and somehow I'm pushing the wrong way with one of the fingers grabbing it. I really can't explain it, but it's really happening. Weird.
    So I did come up with another fix: I put a rubber band around it, and if I look directly at the knob, and insure that it is indeed rotating only in the direction I intend, then volume changes appropriately. Mostly. Once, it did go the wrong way. !!
    but at least I've got the steering wheel. All good, here.
  5. bisco
    52,904
    there is a fellow here, selling knob extensions. i wonder if they would help.
    WilDavis likes this.
  6. PriusNeckBeard
    376
    211
    Cincinnati
    Interesting..
    Even with the rubber band on the knob:
    If I turn it 1/4 turn, the volume will stay the same volume or go up by like 5.
    1/2 turn is about the same, mostly.
    Keep doing it...it can get crazy loud.
    But a full turn may be better.
  7. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    559
    Tucson, AZ
    2021 Prius
    Sounds like something is defective. The radio volume knob is not a regular potentiometer with a resistive strip and a limited range of motion. As it turns it provides a digital step to a controller which is supposed to increment/decrement the volume. Yours certainly isn't doing that. Something to check whenever you experience electrical funny business is the state of charge and age of your little 12V aux battery. Probably 4-5 years old now if it is the original. Maybe pull it out and have it load tested. And maybe the electrical reset might do something also.
  8. PriusNeckBeard
    376
    211
    Cincinnati
    You are spot on, on all that. Thanks!!
  9. PokerMunkee
    PokerMunkee Junior Member
    34
    23
    Denver, CO
    Did you ever figure out a fix? My JBL system on my 2011 does the same thing :(
    If I i press the knob up or down while turning it, it seems to work much better.
    If I can find a system that works with the steering wheel buttons, including bluetooth calling, I'll probably upgrade to a new headunit. Just weird it does this!
  10. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    The carbon strips inside the potentiometer residue scraps off over time from constant knob adjustment. In the audio world, knobs and faders go through the same thing, audio engineers have to spray the carbon strips to blow the residue and a protective layer coat is to preserve the carbon from excess stripping. When excess carbon residue builds up in clumps and the contacts touches it, this cause non linear volume/signal changes. Use caiglube deoxit and blast into the pot with knob removed.
  11. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Aren't there volume control buttons on the steering wheel?
  12. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    The volume pot isn't a potentiometer , but rather a rotary shaft encoder! As with all things digital these days it generates an on/off square wave to adjust the volume. Either the encoder is becoming defective, it can be replaced, if you can find the right replacement. Or, the IC chip which receives the pulses is going bad. Since the steering wheel thumb switch seems to work seems to function properly, my first step would be to pull the radio out of the car, pop the covers and see if the rotary encoder has a mfg number on it, and search the interweb for a proper replacement. This fix is not for the feint of hart, nor the electronically/mechanically challenged! With that being said, the alternative is a trip to the dealer and replace the radio a they do not do component level repairs!
  13. analoggirl
    analoggirl Member
    155
    28
    Asheville, NC
    AzWxGuy- How do I do an electrical reset? My horn was only working if turned to the left. After visiting the dealership and told the part was $800 I left and decided to find my own fix. Now the horn doesn't work at all and the radio stopped working. Then this morning the radio turned on if I pressed one of the preset buttons. All the preset station buttons now act as an on/off switch to the same station. It seems to be there is a loose wire or electrical glitch. How can I 'reset' the electrical?
    Thanks!
  14. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    559
    Tucson, AZ
    2021 Prius
    You might need a replacement 12 volt battery if yours is original. I just replaced mine not long ago. A weak 12 volt auxiliary battery can cause all sorts of electrical issues. That could explain why your radio isn't working properly. The intermittent horn issue is probably something else like a busted clock spring. This is a set of conductors wrapped in a spiral and placed inside the steering wheel column so all the buttons on your steering wheel operate things. You didn't say what service the dealer was going to charge you $800 for. Maybe it was this clock spring. There are other threads about clock spring problems. Quickest way to do an electrical reset is to find that little 12 volt battery in the right rear corner of your car and remove the negative post clamp for a minute or two. Good time to check the voltage on it if you can. This will also erase your trip odometers, your power window auto functions, your radio presets, and reset various volatile data stores in various ECU's throughout the car. Good luck.
