Rain-X based product questions
Discussion in 'Prime Main Forum (2017-2022)' started by Deleted member 111882, Oct 11, 2017.
  1. (This probably should be in the Prime Care subform)
    1. If I still have a lot of the original blue windshield fluid (financed last month from a Maine dealership, it goes below 0F each year), are there any concerns related to sensors, etc. if I fill the rest of the reservoir with Rain-X windshield fluid, or do I have to finish the blue stuff first? Basically I want to know if there is any problem with using Rain-X windshield fluid specifically in the Prime before I add it.
    2. If I go to a Toyota dealer and have them install Rain-X wiper blades, what should I do with the old/stock blades, which are only a month old? Also, how do I clean the Rain-X wiper blades after a month of driving and the blades get gunk on them?
    3. If I get Rain-X blades, do I need to (and should I) get the Rain-X windshield fluid?
    As far as the regular Rain-X bottle application, I've already done this carefully by hand and with new microfiber towels on all of the windows except for the rear.
  2. Mark57
    2,945
    2,740
    OK
    Item 1 . . . Be sure to use "at least" the Rain-X "All-Season" version which is good to 0°F. The Rain-X De-Icer version is good to -25°F. Not all Rain-X is the same. Read the temp specs before buying. Not knowing what fluid you have from the dealer, and with your temps, I'd probably try to remove or use up most of what you have before adding the new Rain-X so as not to dilute it's temp qualities.
    Item 2 . . . keep you new old blades as a backup for summer. I'd defer to Rain-X for cleaning instructions if any.
    Item 3. . . One does not depend on the other.
  3. Mendel Leisk
    41,925
    Isn't Toyota washer fluid always pink? Not very important, just a thought.
    The bottle up here:
  4. Mark57
    2,945
    2,740
    OK
    I know the Toyota "red" engine antifreeze coolant is, but don't use that acid stuff here. (grin) My 2017 came with blue washer fluid from the port in Houston.
    I've not seen that bottle of washer fluid here locally.
    #4 Mark57, Oct 11, 2017
  5. Trollbait
    12,689
    Check the manual. Our Camry one says not to use Rain-X like products on the glass over the cameras/sensors for the safety systems and such.
  6. I could not tell what the color of the stock fluid was, even with a flashlight. The stick that came with the washer did not give away the color. I didn't see any red alarms in the manual concerning the use of Rain-X. *shrug*
  7. Prodigyplace
    12,682
    11,833
    Central Virginia
    Toyota Canada could source it domestically.
  8. Dm84
    Dm84 Member
    60
    38
    MA
    I have "blue" windshield washer fluid that's good down to -25F. If I were in Maine I'd probably spring for something good down to -40 but I think you'll be ok.
  9. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    I'm guessing this means that you can use Rain-X water repellent on the windshield as long as you mask off the sensor area before applying it? Then again those sensors might have a pretty wide field of view so you might not have much windshield area that you could apply it to.
  10. MNdriver
    MNdriver Senior Member
    549
    577
    Wish I’d read this before applying Aquapel. At least my high beam assist is still working.
  11. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    Could not find specific on RainX in the manual, but found this section about water-repellent coating on page 557.
    ■Front side windows water-repellent coating The following precautions can extend the effectiveness of the water-repellent coating.
    ●Remove any dirt, etc. from the front side windows regularly.
    ●Do not allow dirt and dust to accumulate on the windows for a long period. Clean the windows with a soft, damp cloth as soon as possible.
    ●Do not use wax or glass cleaners that contain abrasives when cleaning the windows.
    ●Do not use any metallic objects to remove condensation build up.​
  12. Salamander_King
    11,024
    8,970
    New England
    The manual also states on p593:
    ■Do not use any fluid other than washer fluid Do not use soapy water or engine antifreeze instead of washer fluid. Doing so may cause streaking on the vehicle’s painted surfaces.
    ■Diluting washer fluid Dilute washer fluid with water as necessary. Refer to the freezing temperatures listed on the label of the washer fluid bottle.
    So, my take is that there is no mentioning of specific fluid to use or not to use as long as it is "washer fluid" appropriate for the temperature range. I have used all kinds of washer fluid in the past for my other vehicles ranging colors from blue to yellow to orange, and never had ill effects mixing them, though most of the times I would add new bottle only after previous winter fluid ran out, and none of my previous vehicles had sensors on my front glass nor the cameras behind the glass. From my experience during the coldest months of winter when the temp gets below 0F, even with De-icer type washer fluid that is supposed to work down to -34F, freezes on the windshield without sufficient worming by defroster blowing.
    -40C... that's -40F. I have not seen any over the counter washer fluid that goes down that low. I wonder what this bottle cost???:eek:
  13. Since2002
    936
    1,098
    Duluth, GA
    Just to be sure that it's clear (no pun intended) we are talking about two different types of products. Rain-X is a brand but it's also sort of the catch phase for water repelling products that you apply to your windows. The OP's question was about mixing windshield washer fluid, he mentioned the brand of replacement washer fluid that he purchased which happens to be Rain-X, somewhat clouding the issue (oops there I go again)
    The OP's question related to mixing different types of washer fluid, the answer seems to be that that should be fine as long as you pay attention to the temperature rating of the products that you are mixing, and when it doubt to use up the first one before adding the second.
    Meanwhile Trollbait mentioned that his Camry manual says to avoid using "Rain-X like products" over the sensors. I would think that is referring to the applied water repellents and does not prohibit using Rain-X brand washer fluid. But Rain-X does claim that their windshield washer fluid has water repelling properties. So is that a problem for sensors? Meanwhile the Prius manual apparently has no such restriction, which is a bit mystifying since these are presumably similar electronic systems.
    Trollbait likes this.
  14. Well the dealership said that their stock windshield fluid goes down to -32F, and the bottle of Rain-X windshield washer fluid that I was thinking of getting goes down to -25F. Having used it in the past when I had my Prius c... no problem in the winter. But my concern was more so, with the Prime Advanced having more specialized sensors, if something as glue-like as Rain-X windshield washer fluid would have adverse effects on the sensors.
  15. VTBIGDOG
    VTBIGDOG Active Member
    211
    146
    -40C IS the same temperature as -40F.
  16. Salamander_King
    11,024
    8,970
    New England
    Yes, I know, as I wrote "-40C... that's -40F." BUT, the lowest temp on any wash fluid I have purchased OTC is the de-icer type wash fluid from Prestone. Prestone De-Icer washer AS250 - Read 1 Reviews on Prestone #AS250 It already cost premium compared to other brand that has higher freezing temp, but this one only goes down to -34F. That's why I am wondering how much Toyota fluid costs.
  17. Dm84
    Dm84 Member
    60
    38
    MA
    It really depends on where you're located. In extremely cold climates the stores sell wiper fluid that's good down to -40.
  18. Trollbait
    12,689
    I note the section is talking about side windows and not the windshield.
    Yes, I was talking about the glass treatment, but I do believe it is also in the washer fluid.
    I think the worry is that the treatment could distort or reduce the light reaching the senor. If not applied right, Rain-X can leave a haze for example. So no risk of actual damage to the senors. The manufacturer warning against treatment use could also be CYA from the legal department.
    If the manual doesn't say anything about such treatments, I would not worry. Our Camry is a 2016, so the manual is old for comparing capablities of the actual sensors, and there are legal considerations put into writing the manual.
  19. Salamander_King
    11,024
    8,970
    New England
    The wording on the manual is in fact "Front side windows water-repellent coating." But it's weird why it specifies only the front side windows and not the other windows for this note under "Cleaning and protecting the vehicle exterior" section? It looks almost like typo of "Front and Side windows". BUT then, I don't know why they would exclude Rear window.(n)
  20. Mendel Leisk
    41,925
    $3.95 Canadian, at the dealership.
    FWIW, I find anything can freeze up on the glass, especially before the interior's warmed, regardless of the rating. And we're not that cold here.
    Trollbait and Salamander_King like this.
