Rain ?
Discussion in 'Gen 2 Prius Main Forum' started by bulzeye179, Nov 1, 2012.
  1. bulzeye179
    bulzeye179 New Member
    Was curious how the Prius handles in the rain?
  2. Patrick Wong
    18,210
    6,515
    Not bad if your tires are in decent condition. Replace them when the tread depth drops to 4/32", if you are concerned about wet weather traction. (The legal limit is 2/32" but that is unsafe in wet weather.)
    Data Daedalus likes this.
  3. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    Ive had no problem at all.
    Where I do have a problem is in the wind. The Prius is very susceptible to wind gusts on the road. Rain alone, no problem. Rain w/wind...still not a problem but you will be holding tight to that steering wheel during wind gusts!!
  4. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    The only thing between your Prius and the ground is the tires. Good tires are essential to good handling in slippery conditions. If you're even slightly doubtful about your tires, it's time to replace them... a set of tires is much cheaper than a wrecked car or a trip to the hospital.
    Since the Prius is a front wheel drive car, it has an advantage over rear wheel drivers in that it is a lot more forgiving in slippery conditions. Coupled with the Prius's traction control, you shouldn't have to worry unless you're doing something stupid... no amount of safety features will make up for bad judgment.
  5. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    If wind is bothering you, I can recommend this stiffening brace:
    prius g7 | eBay
  6. maestro8
    471
    109
    nor cal
    *This statement has not been evaluated by the FDA. This product is not intended to diagnose, treat, cure, or prevent any disease.
  7. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    The strait line stability of the Prius is greatly improved by going to a wider section tyre and raising the tyre pressures.
    I can only guess how the US version handles in the wind with it's narrow 185 section tyres and the high side walls with 15 inch rims (except touring).
    The UK/European Prius come with 195 section tyres on 16 inch rims and that does not handle side winds well, but going to 205 section tyres really does transform the car. This in theory should reduce the MPG figures but I find that is not the case.
    Going on to the OP's question with good tyre treads I have never had a problem with wet or even deep puddled roads.
  8. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
    And if you get an upgraded brace may I suggest you give away or sell cheaply your stock brace to a Gen II owner that doesn't have a brace (If I remember correctly they fit). I know for sure my Prius doesn't have one yet.
  9. maestro8
    471
    109
    nor cal
    This is a double-edged sword. Raising the tire pressure can reduce the contact patch, hence reducing traction. Not something you want to be doing in the wet.
  10. Britprius
    5,194
    1,922
    But if you go to wider tyres you increase the contact patch, and there are those that would argue that by decreasing the contact patch you lesson the chance of aquaplaning, so bit of a balancing act.
  11. maestro8
    471
    109
    nor cal
    Taking your statement to its logical conclusion, we can eliminate the issue of aquaplaning by driving cars that don't touch the ground at all.
  12. Britprius
    5,194
    1,922
    Your logic not mine.
  13. maestro8
    471
    109
    nor cal
    Thanks for the credit but it's not me.
    It's called "linear correlation" and it's been in use since the 1850's.
  14. Britprius
    5,194
    1,922
    But cars that do not touch the ground, don't they call them aircraft.
  15. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  16. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    Yes Gen 2 got this skinny brace and I did replaced with the G7 for a long time. Good performance. :)
  17. maestro8
    471
    109
    nor cal
    No, those are called UFOs.
    Aircraft have tires too... unless they're... hydro-planes. :p
  18. Agent J
    Agent J Hypoliterian
    294
    111
    Sydney, Australia
    Raising the temp does reduce the contact patch (if overdone), but it opens up the grooves which is ideal for water channelling and wet weather traction. this will be more of a problem if the tires don't have much groove any more.
  19. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    I had to drive through wind and rain on the highway under hurricane affected weather recently. My 2009 with stock tires at ~ 50 psi did not feel different in handling than under normal dry conditions. I wasn't trying to do any stunt car tricks though - when people ask about handling I always envision those cars zipping in and out of the lanes trying to speed ahead of everyone else, sorry.
  20. maestro8
    471
    109
    nor cal
    That's just it... if you don't test your car's handling, you won't know how close to the edge of losing traction you are. You may be driving just at the limit without even knowing it. This is why it's best not to play with parameters that affect your car's safety.
