Rainbow Prius Hybrid Powered by Lithium!
Discussion in 'Gen 3 Prius Accessories and Modifications' started by jacktheripper, Dec 24, 2019.
  1. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,099
    Columbia, SC
    Well, that's a total non-answer to the question, but don't worry about it. I've accepted that an actual answer will not be provided..
    and now...
    You say you accidently drained the battery to 0 volts.
    The prolong chargers I've used pulse between 0 and 0.35 amps when at low voltage like that.
    You say it took the prolong charger only 10 minutes at a 0.35 amp charge rate (max) to recover the battery enough to start the car. Ten minutes at 0.35 amps....What is that? 0.06 AH?
    Amazing.
    Grit, 2k1Toaster and Ed Beaty like this.
  2. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    @TMR-JWAP at least for the 12 V replacement starter batteries, there is a built in BMS that cuts off at around 10 V, (my understanding). After which it will no longer drain any further. (I assume measuring voltage after cutoff will yield 0 but internally it's kept at a safe minimum level. Maybe something similar?
    moto g(7) power ?
  3. jacktheripper
    jacktheripper Senior Member
    284
    561
    Puncture test results, I think I post the first video on another wrong thread, sorry.
    more test videos coming. (overcharge, overdischarge and all the spicy stuff)
    Lithium battery puncture test - horizontal
    delta voltage : 3.292v to 0.022v
    case temperature: 18C to 33C
    observation: smoke, smell, noise, no spark, no flame, minimum thermal runaway
    Lithium battery puncture test - vertical
    delta voltage : 3.292v to 3.25v
    case temperature: 17C to 18c
    observation: small drop in voltage, no smoke, no flame but with smell
    mjoo and SFO like this.
  4. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    @jacktheripper does your Lithium hybrid battery assembly carry a warranty?
  5. AzusaPrius
    AzusaPrius Senior Member
    2,258
    952
    mjoo likes this.
  6. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
  7. AzusaPrius
    2,258
    952
  8. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Factory Warranty
    A 2 year or 25,000 mile warranty on the modules. Fleet vehicles included."
    moto g power ?
    jacktheripper likes this.
  9. AzusaPrius
    2,258
    952
  10. jacktheripper
    284
    561
    tony_2018, Threej and mjoo like this.
  11. jacktheripper
    284
    561
    per-order is officially open now at ProjectLithium.com
    The last site/platform was too sketchy so I completely redone it with Shoptify, take a look and spread the words, 24 packs remaining in the first batch, with early bird discount, schedule deliver in May.
    kenoarto, Max Taiwan, Threej and 3 others like this.
  12. bisco
    52,888
    looks good jack, all the best!(y)
  13. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Is there a v (wagon) specific battery or just for Gen 3? TIA
    moto g(7) power ?
  14. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Gen3 and the V are the same, so there shouldn't be a difference.
    jzchen likes this.
  15. jacktheripper
    284
    561
    yes,
    Prius V US spec = Prius NiMH
    Prius V EU spec = Lithium already.
    SFO likes this.
  16. ASRDogman
    ASRDogman Senior Member
    8,069
    4,092
    $800 more....that's what I thought.
    Correction: $500 more....
    #296 ASRDogman, Mar 17, 2021
  17. burebista
    burebista Active Member
    189
    130
    Romania
    Do you ship overseas?
    Just curious. For now. :)
    All the best.
    Max Taiwan likes this.
  18. BurkPhoto@aol.com
    56
    High Point, North Carolina
    Wake me up when the battery has specifications proven by at least two independent third parties, a million miles of safety testing, and a firm price... I could care less about pre-release, unverified BS.
  19. jacktheripper
    284
    561
    what do you mean @ASRDogman?
  20. jacktheripper
    284
    561
    more testing videos coming up soon, including UN38.3
    with total of 12 test vehicles running out there, I think a million mile is a few months away but sure, I will wake you up.
    tony_2018, Max Taiwan and SFO like this.
