Rainbow Prius Hybrid Powered by Lithium!
Discussion in 'Gen 3 Prius Accessories and Modifications' started by jacktheripper, Dec 24, 2019.
  1. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,099
    Columbia, SC
    @PriusPilotSurfer recently wrote...
    This author/vendor here is an independent company bringing us hope and something new at a fraction of the cost with better specs all across the board.
    Can you clarify this?
  2. tony_2018
    tony_2018 Member
    227
    68
    Would I need to charge these before using? If so will the current chargers developed for the 3rd gen Prius work?
    jacktheripper likes this.
  3. PriusPilotSurfer
    PriusPilotSurfer New Member
    Orange County
    Actually, these threads are here for everyone to comment and share their thoughts. You can disagree, you can appose, you can have your thoughts and no one has said not to share what your thoughts are. It is the manner that some people/authors of replies present themselves. If you want to disagree, do so in an adult and respectable manner. This is a discussion board and some replies are disrespectful and even down right make no sense. Agree to disagree, we are one community here and we learn together. If you have something to say, do so with some level of respect.
    nssdiver, Threej and TheChip like this.
  4. PriusPilotSurfer
    Orange County
    Cry baby, okay then. At least I can spell. I looked all over the internet and can not find 'enerwater'. Grow up sir.
    nssdiver and TheChip like this.
  5. jacktheripper
    jacktheripper Senior Member
    284
    561
    @tony_2018 unlike NiMH, the Lithium self-discharge is extremely low, you don't need to do anything when you receive the pack.
    You will also find the benefit later on, your Prius will always have the same level of juice as last night :)
    Max Taiwan and tony_2018 like this.
  6. AzusaPrius
    AzusaPrius Senior Member
    2,258
    952
    Max Taiwan likes this.
  7. tony_2018
    tony_2018 Member
    227
    68
  8. tony_2018
    tony_2018 Member
    227
    68
    So far this Prius is about to be a brand new car. Bought it for a steal really so the amt of money I put in so far would be the same as buying a used one with 150k miles, I think.
  9. Max Taiwan
    Max Taiwan Active Member
    428
    384
    Taipei
    2018 Prius v wagon
    Hi Jack Prius C pack coming soon?
  10. jacktheripper
    284
    561
  11. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Looked at the projectlithium website and have a few Q's:
    1. What is the kwh of the pack at each cell's max voltage limit (I'm assuming 3.65V for LiFeP04)
    2. Resistance of each module.
    3. How to rebalance modules as they age. Is a jumper wire required or can a prolong charger be used without damaging battery
    I see potential with this pack. Just want to know what I'm buying.
  12. jacktheripper
    284
    561
    great technical question @mjoo
    1. kwh = nominal 16v * 6.5Ah * 14 = 1.456KWh
    2. <10 milli-ohm from Techstrem or Dr. Prius App, 1.5 milli-ohm using 1KHz AC IR measurement.
    3. Balance cable available soon, 30 bucks or you can always DIY, one copper wire connects all positive, and another connects all negative, there is no need to refresh/exercise Lithium, no more uncertainty like NiMH chemistry.
    more FAQ can be found here: FAQs
    mjoo likes this.
  13. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    easy peasy, take the batteries out of the pack and wire all the positive posts together and then do the same thing for negative posts. They will all balance out within few days, no special equipment needed.
  14. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    I am so tempted but our battery is still good...
    moto g(7) power ?
    Max Taiwan, mjoo and jacktheripper like this.
  15. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    :confused: too many panels and too much work. I like my HybridAutomotive harness :). Plug in and done.
    Jumper harness idea #2: Daisy-chain some diodes to cap the voltages of the modules. Then use your favorite traction battery trickle charger.
    hill, Raytheeagle and jacktheripper like this.
  16. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    14S active cell balancer, set it and forget it.
    #336 Grit, Mar 19, 2021
    mjoo likes this.
  17. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    see post #139, find photos of the green bars and look at the base values and unit measurement.
  18. priusCpilot
    priusCpilot Active Member
    663
    210
    LA
    The Plug out looks nice but it's large for bringing along camping?
    My HV battery is good but looking forward to the Prius C kit. May still use a prolong just to push the back to it's last breath.
  19. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    wait you meet Sam spade II.
  20. AzusaPrius
    2,258
    952
    #340 AzusaPrius, Mar 20, 2021
    priusCpilot and jacktheripper like this.
