Rainbow Prius Hybrid Powered by Lithium!
Discussion in 'Gen 3 Prius Accessories and Modifications' started by jacktheripper, Dec 24, 2019.
  1. Rmay635703
    Rmay635703 Senior Member
    2,705
    1,730
    Somewhere in Wisconsin
    2013 Chevy Volt
    gotta convince him to make one for the 2000 Insight :0
  2. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,145
    Franklin TN
    Thats wonderful news! Keep us all updated.
    Rmay635703 likes this.
  3. Max Taiwan
    Max Taiwan Active Member
    428
    384
    Taipei
    2018 Prius v wagon
    Hi Jack! I just went through the 5 months of your work! Looking promising with every page!
    Imagine the applications and convenience of your pack is giving me smiles!
    In theory you could identify which pack is down in the future with your app, and owners can replace that individual cell easily at home.
    Check pack voltage, match the cell voltage to that of the pack and do a plug and play replacement.
    In reality that is what most reconditioned battery means, they took out the rotten egg from the cluster of cells and replace it with a new/working cell. But due to those Panasonic blades it is limiting the owners access to this maintenance from home.
    The way your pack is put together seems easy to service in that aspect.
    Looking forward to new updates! Prius C would love one too! I bet with the same volume of a factory pack you could boost our capacity at least double.
  4. z704w40
    z704w40 Junior Member
    16
    netherlands
    Hi Jack does the pack offer external charging option?
  5. bisco
    52,891
    only in the extra large size
  6. jacktheripper
    jacktheripper Senior Member
    284
    561
    That could bring the Lithium potential to the max, but that will also require additional charging hardware which against my cost saving concept, maybe it could be an optional package.
    Minima Domum and SFO like this.
  7. jacktheripper
    284
    561
    Yes! boost capacity and reduce cost at the same time !!
    Minima Domum and Max Taiwan like this.
  8. Max Taiwan
    428
    384
    Taipei
    2018 Prius v wagon
    HURRY!! Looking forwards to it!
    Aaron Vitolins and Rmay635703 like this.
  9. Minima Domum
    Minima Domum Member
    84
    147
    Adelaide, Australia
    i-Tech
    This is great!
    I've been wondering since before I bought my Gen2 why nobody has done a plug and play lithium pack yet, hopefully my 415,000km battery lasts long enough to replace it with one of these!
    @jacktheripper is it possible to also swap the 12v side to lithium? Do you know what the factory DC-DC charger outputs? I'm assuming it's just a constant 14.x volt power supply so most off the shelf 12v lithium packs with built in BMS will work
  10. Prius717
    Prius717 Junior Member
    51
    Lancaster County PA
    Not sure if it missed it but what do you expect this to cost?
  11. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    Probably about the same, or more than the $1600 batteries back....
  12. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    I could see this being. $2,000+.
    Old technology NiMH is $1,600 for aftermarket pack.
    jacktheripper and hill like this.
  13. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    Jackthe ripper earlier in this thread:
    We'll see.
    Minima Domum likes this.
  14. TheChip
    TheChip Senior Member
    388
    1,211
    Misissippi
    If this ends up coming to market I have a feeling I'll end up getting an extended capacity version.
  15. ice9
    ice9 Active Member
    581
    346
    norfolk va
    2018 Prius
    Spiral Development does have it's advantages, esp if the product is IT intensive. However, it also has its cons - one being that the consumer often does the QA. The Toyota took a quasi Robust Design approach with the Gen 1 & 2 Priuss to ensure that the consumer would get a reliable product at the start. That distinguished it from the rest of the market, which why the Prius was so successful at it's inception.
    jacktheripper likes this.
  16. jacktheripper
    284
    561
    #77 jacktheripper, May 23, 2020
    ice9 likes this.
  17. jacktheripper
    284
    561
    Thanks for reaching out Bran, let's push these Lithium battery to the limit before selling it. Drag race, auto-x, off-road.. you name it !
    #78 jacktheripper, May 23, 2020
    Aaron Vitolins and TheChip like this.
  18. jacktheripper
    284
    561
    Hi Eric, is this $1600 aftermarket pack from Toyota or from that unknown China source?
  19. ASRDogman
    8,070
    4,092
    You can bet they are a china product.
    But, you can send me a pack and I will install it and test it for you in a REAL life usage situation.
    I drive about 700 miles a week. :)
