Rainbow Prius Hybrid Powered by Lithium!
Discussion in 'Gen 3 Prius Accessories and Modifications' started by jacktheripper, Dec 24, 2019.
  1. jacktheripper
    jacktheripper Senior Member
    284
    558
    All my Prius are running on home-made 12V Lithium, using a $5 Harbor Freight ammo case, they have been in the car for 3 years and still running like new, maybe I should have a DIY session, for me this is A-MUST for all Prius.
    0.30 Caliber Ammo Box
    and look at these mess!!! I have been testing different battery cells and protection circuit all these years, time to bring it to the market!
  2. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,145
    Franklin TN
    Beyond excited for this project. My Ford C-Max just hit 167k today. The lithium back is working great at almost 8 years old.
    I think a aftermarket lithium hybrid battery could breath new life into a old worn out Prius. Making it better than new in some ways! :)
    Max Taiwan, jacktheripper and TheChip like this.
  3. jacktheripper
    284
    558
    That's what I figured, I have been helping this made in China NiMH battery factory for years, we communicate over WeChat and I've even tried to visit them in China without luck, obliviously they don't want to get sued by no one. Their battery still at Gen1~Gen2 quality in terms of internal resistance, voltage spike crazy compare to stock, and degradation is also another problem, 3 years and I am seeing half capacity... They came out with a newer version and have me tested, it's better but it is HEAVY as hell !!
  4. ASRDogman
    ASRDogman Senior Member
    8,052
    4,083
    "it's better but it is HEAVY as .."Then how can it be better?
    Extra weight, needs more power to move.
    It should weigh less, with more power.
    You can just get a 2nd Prius pack and run it in parallel to the original, giving it
    twice the power.
    chronon and jacktheripper like this.
  5. jacktheripper
    284
    558
    IR is better but much heavier, feels like they put a lot more material in there to reduce the resistance, I will snap a picture when I dissect the battery.
  6. ASRDogman
    8,052
    4,083
    UNLESS, it heavier with a LOT more power, to override the extra weight, AND give a longer
    driving distance on the battery, and better charging/discharging rate, and at LEAST last as long,
    or better is longer life than original, for the same or less cost, it doesn't seem to be worth it.
    I don't see a reason for getting it if it is not better than what is already out there, for equal or lower cost.
  7. bisco
    52,803
    the good news is that the longer this takes, the cheaper the batteries get.
    and there are still tons of early gen2's with original batteries that will need replacing someday.
    oem nimh are unlikely to drop much below todays prices, and only some parts of the country are seeing them down near $1,600.
    plus, worldwide sles would be incredible
    Rmay635703 and Aaron Vitolins like this.
  8. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    I believe he is talking about batteries from http://www.newpriusbatteries.com/
    His batteries are from China but he claims that they are higher quality that other Chinese batteries
    Here is a long thread about them: Prius Battery Replacement (GenII) Like you've never seen - NEW Cylindrical Cells | PriusChat
    How about an estimate on when that might happen.
    #88 royrose, May 23, 2020
  9. ASRDogman
    8,052
    4,083
    Not everything made in china is junk. A lot Apple products are made there. But they have
    stricter guide lines for how things are build. And then the cheaper china copies are junk!
    They use inferior components and are put together cheaply.
    You just have to be careful from where in china you get it.
    Robert Holt and jacktheripper like this.
  10. Minima Domum
    Minima Domum Member
    84
    147
    Adelaide, Australia
    i-Tech
    Good to hear! A new thread on how you did the 12v lithium would be amazing, if not its enough just knowing that it works for me to give it a go
    sjochssr likes this.
  11. bisco
    52,803
    there's a thread here if you can find it. a member put in a lithium 12v a few years afo with no issues. it wasn't cheap at the time though.
    Minima Domum likes this.
  12. George W
    George W Senior Member
    937
    520
    San Antonio
    I wonder how a Lithium 12V would fare when a Prius Dweller wants to connect their 1K inverter to it?
  13. jacktheripper
    284
    558
    If you hook up a 1000watt inverter, most of the juice actually come straight from the traction battery through car inverter.
    GG707 and George W like this.
  14. GG707
    GG707 Member
    62
    26
    athens
    Excel
    So, how many kw is the stepdown converter for the 12v?
  15. GG707
    GG707 Member
    62
    26
    athens
    Excel
    Rmay635703 likes this.
  16. jacktheripper
    284
    558
    What a weird 2020 so far, but finally, something good is happening!!
    A sneak peek of the latest and greatest prototype being assembled:
  17. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    Dead link
  18. George W
    937
    520
    San Antonio
    So 9 seconds of Nada?
    bisco and ASRDogman like this.
  19. ASRDogman
    8,052
    4,083
    That is what you get, for your money!
    Still no info on why it would be better that any other new battery....that costs less.... waitinggggg....
  20. PriusCamper
    PriusCamper Senior Member
    13,420
    5,418
    Pacific Northwest, USA
    Awesome, thanks for sharing, it's nice to see some close ups of how these packs are going to look! So exciting! Let me know if there's any way I can help?
    Max Taiwan likes this.
