Raise the Front suspension?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by kenmce, Sep 29, 2012.
  1. kenmce
    kenmce High Voltage Member
    1,552
    525
    NY
    Anyone know if there is an easy way to raise the front suspension on a gen. II, and if it will screw up anything?
  2. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    i don't think there's an "easy way" that would be safe... airbags would be cool, or maybe some adjustable coil-overs.
  3. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    *EDIT* I didn't see the part about EASY... lol..*
    Might look into doing something similar that 'Prius70' did ... only instead of lowering it...
    going lower. . .inserts. . . | PriusChat - Have the mounts re-welded a bit higher..
    Also, what about Coil-Over sleeves? Might be able to actually raise the front over the stock height...
    BTW...why do u want to go higher?
  4. Britprius
    Britprius Senior Member
    5,194
    1,924
    Herefordshire England
    How about 1 inch "if that's the raise you want" alloy ring spacers on tower mounts.
  5. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    So something like the SoCal East County trucks?? lol
  6. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
  7. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Taller tires work too.
  8. kenmce
    1,552
    525
    NY
    Tired of scraping the air dam on driveways.
  9. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Tried going in on an angle? That usually helps me and i'm stock height currently but even when i've driven lowered cars...taking a curb/driveway/speedbump at an angle always helped me. Its kind of a pain, but worth the hassle when lowered.
  10. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    By The Way, I scrape MUCH less in the v than I did in the Gen 2.
  11. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Think it has to do with the stock front suspension being 'soft' ?
  12. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    The air dam is a cheesy strip of plastic. It will survive hundreds of scrapes.
    Why undergo hundreds of dollars to modify the suspension, change the ride and/or handling of the car just for the sake of a cheesy strip of plastic?
  13. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
