Raise the Ground Clearance by 1"?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by torr310, Sep 12, 2013.
  1. torr310
    torr310 Junior Member
    37
    All threads I saw were about lowering, but I would like to raise the ground clearance by 1".
    Is this a bad idea? Has anyone ever done that?
    Any comments or suggestions are welcome.
    Thank you,
  2. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    It might hurt your higher speed mileage a bit. There may be some mild unintended changes to wheel alignment, but probably nothing dire.
    Are you having problems with it at stock height?
    torr310 likes this.
  3. torr310
    37
    Yes, I hit dips and bumps sometimes... My vision couldn't see them clearly. >_<
  4. alekska
    alekska Active Member
    435
    138
    Atl
    Maybe you can get tires with higher profile? Something like 195/70/15 ? That should mess up the speedo and slow down the acceleration a little but the car will be higher with no suspension mods.
    - Alex
    torr310 likes this.
  5. Skunkworks
    Skunkworks Member
    101
    Contact Eibach spring, I'm sure that something can be made.
  6. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    Have you tried raising your seat hight?
  7. Sfcyclist
    Sfcyclist Senior Member
    1,621
    375
    SF, CA
    Not sure if just raising the car will eliminate that issue. :confused:
