Raised-height option? and smaller gas tank awd-e
Discussion in 'Gen 4 Prius Technical Discussion' started by davran, Apr 15, 2019.
  1. davran
    davran Member
    99
    97
    BC, Canada
    2019 Prius
    Base AWD-e
    Nerding through my owner's manual, I found a mention of a raised-height option; I assume it's for certain countries?
    Dimensions and weight
    Overall length 180.1 in. (4575 mm)
    Overall width 69.3 in. (1760 mm)
    Overall height*1
    2WD
    models
    Without raised
    vehicle height 57.9 in. (1470 mm)
    With raised
    vehicle height 58.7 in. (1490 mm)
    AWD models 58.1 in. (1475 mm)
    Anyone where where a raised-height Prius is an option?
    52,927
    and small gas tank?
  3. davran
    davran Member
    99
    97
    BC, Canada
    2019 Prius
    Base AWD-e
    ...and, gas tank capacity on awd-e is smaller:
    Fuel
    2WD models AWD models
    Fuel type Unleaded gasoline only
    Octane Rating 87 (Research Octane Number 91) or higher
    Fuel tank capacity
    (Reference)
    11.4 gal.
    (43 L, 9.5 Imp.gal.)
    10.6 gal.
    (40 L, 8.8 Imp.gal.)
  4. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    They did have to make room for the rear motors...
    knockknock_2 likes this.
  5. davran
    davran Member
    99
    97
    BC, Canada
    2019 Prius
    Base AWD-e
    I was assuming that was the case; it's the "raised vehicle height" stat that I'd like to track down, as to where it's an option.
    #5 davran, Apr 16, 2019
  6. Tideland Prius
    16,684
    If I had to guess, it's Mexico. "rough road specification".
    That said, the AWD-e is 0.2" higher than the standard Prius (5.3" vs. 5.1")
    davran and alanclarkeau like this.
