Raising ground clearance on 2016 prius?
Discussion in 'Gen 4 Prius Accessories and Modifications' started by JimmyPri, Mar 3, 2017.
  1. JimmyPri
    JimmyPri Active Member
    201
    245
    Hilo, Hawaii
    I think that's what I said. Although I didn't say it ran rings since I never drove any older year Prius cars. It was someone else that commented that the gen4 handles poorly.
    RCO and alanclarkeau like this.
  2. tucatz
    tucatz Active Member
    501
    417
    Manzanita, Oregon
    Four Touring
    Can we install "regular" 17" tires on a touring? This would raise the ground clearance by a couple of inches, probably make for a quieter ride. But will they fit in the wheel wells, and work?
    RCO likes this.
  3. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    They're the same diameter/rolling circumference, wouldn't make any difference, in fact minimally smaller with 17"
    195/65/15 - diameter 635mm, rolling circum 1994mm
    215/45/17 - diameter 625mm, rolling circum 1963mm
  4. tucatz
    501
    417
    Manzanita, Oregon
    Four Touring
    No, I meant putting a 17" tire on my 17" rims. Not a touring tire, but the type used on a truck or SUV like a Highlander.
  5. alanclarkeau
    7,045
    7,593
    That is a 17" tyre.
    You'd need to put a high profile tyre - and that would mess up steering angles as well as your speedo, that's if it didn't foul the guards - something like one of these - with the 2nd, the speedometer would be 18% wrong.
    RCO and tucatz like this.
  6. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Big tyres on the rear, 70s dragster yay :LOL:
    RCO and Prodigyplace like this.
  7. Prodigyplace
    12,626
    11,808
    Central Virginia
    ... BUT drive wheels are on the front! I do not want to drive looking up to the sky!
    kithmo likes this.
  8. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Doh ! :oops:
    RCO likes this.
  9. Toppcat
    Toppcat Member
    223
    69
    Northern California
    air suspension be able to raise a few inches and set it oN the ground when park!
    kithmo, RCO and krmcg like this.
  10. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Easy peasy! Turn your baseball cap around so the peak is to the front!! :ROFLMAO:
    kithmo and Prodigyplace like this.
  11. Charles73
    Charles73 Junior Member
    los angeles
    I installed spring spacers on my 2012 Prius 4. Purchased at autozone $9 per kit , 2 kits needed.
    Installed the 1 to 11/2 kit in rear and the 2 to 21/2 kit in front. This brought the car up 1 inch all around.
    It now clears my drive way. Mileage was not affected. I recorded the same gas mileage over 2 tanks after installation,
    no change. Slightly firmer feel on road.
  12. Charles73
    los angeles
  13. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    A ladder on the roadway raised the ground clearance on one side of my car by the thickness of the plastic underside cover. I actually didn't notice it came off. So now when turning left out of my driveway I scrape. Returning and turning right, it does not.
    RCO likes this.
  14. Charles73
    los angeles
  15. Charles73
    los angeles
  16. ExMachina08
    ExMachina08 Junior Member
    72
    27
    United States
    I would love a small lift kit for my Gen 4. I want slight larger tires to give myself a bit more clearance to drive the trails out to some local hikes. Otherwise I will be looking into a Rav4 Hybrid or a Subaru Crosstrek. I checked into the Dazer site posted earlier and it appears that they have not started selling their spacer kit or body mods yet.
    PriusOffroad likes this.
  17. ExMachina08
    72
    27
    United States
    I was able to locate the website where they sell the Dazer Prius-X suspension kit. I'm looking into what it would take to get one and also what size tire/rim combo they are able to fit with the lift. Unfortunately the full suspension kit looks like its lands around $2,100 USD so that's a bit outside of my budget.
    株式会社シーザー|DAZER プリウス-X
  18. bobzchemist
    bobzchemist Active Member
    507
    342
    Kennesaw, Georgia, USA
    Charles,
    Can you link to the specific parts you bought, please? Looking on Autozone isn't helpful at the moment. (And if you could give more details on how you installed them, that would be awesome)
  19. jdenenberg
    jdenenberg EE Professor
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
  20. Prodigyplace
    12,626
    11,808
    Central Virginia
    tucatz likes this.
