Raising of cargo space floor platform
Discussion in 'Prime Main Forum (2017-2022)' started by LithiumMan, Oct 5, 2016.
  1. Prius Maximus
    Prius Maximus Senior Member
    956
    811
    Northeastern IL
    I can't find that thread. It must be lost in all the luggage and cargo in the back of the Prime...
  2. GT4Prius
    GT4Prius Active Member
    530
    412
    Cumbria, UK
    Excel
    Thanks for the info. I can't find this thread either?
    51,950
    sorry, i was kidding. the complaints are in almost all the prime threads.:cool:
  4. Jan Treur
    Jan Treur Active Member
    240
    168
    Heiloo, Netherlands
    Is it known how long the cargo area is with back seats down, measured from the backside of the front seats? Is it long enough to put a bicycle there? And how high is the opening at the rear? This might be a second-choice alternative when no bicycle rack is possible.
  5. GT4Prius
    530
    412
    Cumbria, UK
    Excel
    Not sure if this helps to estimate the cargo capacity of the Prime, but I see that the UK Gen4 sales brochure lists the following Luggage capacities without space saver tyre:
    Up to tonneau cover, 343 litres
    Up to roof, 502 litres
    Seats down up to roof 1558 litres
    I know we don't necessarily think these figures are realistic, but do we have the same figures for the Prime for comparison?
    Sorry in advance if this is already posted here somewhere, I got a bit lost with all the different stats that have been discussed.
    wjtracy likes this.
  6. bisco
    51,950
    we really need some measurements of the production car. height, width, depth in various areas.
  7. Tideland Prius
    16,559
    @wjtracy, we have confirmation numbers!
    For tire repair kit:
    So it's 12.1 cu ft under the rear tonneau cover
    17.7 cu. ft. up to the roof.
    55.0 cu. ft. with the seats folded.
    So where's the extra 10 cu. ft. coming from. in the (supposedly) seats up position for the North American Prius?
    drash and wjtracy like this.
  8. bisco
    51,950
    probably a mistake, or a different way of measuring.
  9. Tideland Prius
    16,559
    Yeah we're trying to figure out the latter.
    Basically, 10.4 cu ft. (27.4-17) is 2.182x2.182x2.182 feet box or 66.5x66.5x66.5 cm box
    Or a 2.750 feet x 2.750 feet isoceles triangle (83.824 x 83.824 cm triangle).
    #89 Tideland Prius, Nov 2, 2016
  10. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    EPA Cargo Space (27.4 ft3) is apparently a different way of measuring, I suspect having to do with window placement and seat placement.
    Suffice it to say, Total EPA space = EPA cargo space + EPA passenger space. I assume the EPA Total Interior Space is a good number, but they allow Liftback manufacturers slack on how they define the "gray area" that could be considered either way. I do not like the EPA Cargo space definition, and I assume it is intentionally misleading to allow green cars to claim large cargo space (that does not actually exist).
    Now all we need is the spare tire version numbers (Level 3).
    We are only halfway there TideLand...and I think there is interesting info to be revealed if we had those numbers (I wonder if there is some minor design difference between Level 3 and 4 that we do not yet understand).
    #90 wjtracy, Nov 2, 2016
  11. Tideland Prius
    16,559
    I'll tell you what, a very, very rough estimation by me resulted in 328 litres under the tonneau cover (with spare tire) or 11.58 cu. ft. Considering I overestimated the enclave area (did not take into account the slope and assumed a cuboid), I accounted for the recline in the seat back but did not account for the widening of the main cargo area (underestimated) and averaged the length of the cargo area (it curves at the rear bumper.. so possible underestimation there).... I'd say that's a very close estimate. Esp. since I don't know what they used as under the tonneau cover. My height could've been underestimated there (I used the height as the floor to the part where the plastic pieces are. The roller tonneau cover would sit a bit higher than that since the cargo light is in the plastic area and sits below the cover (while my volume doesn't include the cargo light... so more underestimation there.
    If anyone's curious, I'll post my very rough numbers soon. I'm gonna calculate the total area now... stay tuned.
    Edit: If I use 39.6cm cargo height (that's the height of the cargo area at the rear), I end up with 363.38 litres or 12.784 cu. ft. Over estimation of course because I did not account for the slope of the enclaves)
  12. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
  13. Tideland Prius
    16,559
  14. bisco
    51,950
    when will we se the first one on a lot? i see that ventura toyota already has them on their inventory list. then someone can go with a tape measure.
  15. Trollbait
    12,543
    Different measuring standards. The US basically goes in with a tape measure for hatchbacks. In Europe, they might use a standard like what we use for trunks, filling up the space with standard sized boxes, and just counting them. This will result in a conservative number since the nooks on the edge are ignored, and space uncounted from the hatch's slant.
  16. Tideland Prius
    16,559
    Yup. See my calculation thread. That's pretty much the conclusion I came to after crunching the numbers.
  17. DavidA
    2,345
    1,821
    Chicago western burbs
    No one (including me) has yet used my proposed method of drilling a hole in the roof and seeing how many ping pong balls can fill the entirety of the passenger space. When they do, then it will become a universal standard for all vehicles.
    KrPtNk likes this.
  18. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Something wrong with putting the car on a scale and filling it with water?
  19. DavidA
    2,345
    1,821
    None, whatsoever. I just thought that ping pong balls would be more Mythbusters-like and add some excitement to the testing. Water, or any other liquid (perhaps not acid) would no doubt prove more accurate for volume, assuming when it is released the car's components wouldn't trap the liquid like a sponge, which they would. Ping pong balls are dry by nature. Ball bearings could also be used, but... the weight - that could be a problem.
  20. Lee Jay
    5,850
    4,036
    Well, neither is really indicative of the way cars are actually used. Most things are rectangular or square (i.e. boxes of things). Given the reputation of the Prius, I suggest filling every nook and cranny with Rubik's Cubes, and counting them up.
    Tideland Prius likes this.
