Ran into another problem.."check hybrid system"..
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Ohsheet, Oct 28, 2024.
  1. Ohsheet
    Ohsheet New Member
    So I changed the head gasket on this 2013 Toyota Prius Hybrid recently and I'm sure you all know all that that intels..so I connect everything back (hoses, and wires). I go and start it up after putting in the fluids and it's a little bit shaky when started..then In about 20 second it just stops/turns off and says "check hybrid system pull over to safe place" and I can kinda smell gas.. if anyone could help me out or lead me the right direction, id highly appreciate it, thanx in advance
  2. Brian1954
    Brian1954 Senior Member
    2,496
    999
    South Central PA, USA
    You need a scan tool to read the trouble codes.
    https://priuschat.com/index.php?posts/3290690
    #2 Brian1954, Oct 29, 2024
