Ran out of fuel AND battery!!
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Yuval Legendtofski, Mar 9, 2013.
  1. Lutchenko
    Lutchenko Will Perrin
    307
    211
    Milton Keynes England
    I can feel a poll coming on along the lines of.....
    How many people, should they happen to run out of fuel, would actually post it on here?
    NDcowPoke, KK6PD, Matt H and 2 others like this.
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    The very accurate advice I posted was not theory. I did not blame others or pretend that the car was flawed.
    Blu-ray likes this.
  3. boppo
    boppo Active Member
    799
    139
    Owego, NY
    I guess if the OP like to run the tank down that low he should a least carry 3.5 gals with him at all times and make sure he fills it back up when he runs out.
  4. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    This is hilarious. :ROFLMAO:
    This issue is one of those things... we've seen a few threads on it here already and its in every guide for beginners I've seen (including What every newb should know | PriusChat ) so the hot tip kind of appears to be "don't run out of fuel".
    From previous posts and mention of the RACV in the first post, Yuval's a fellow Australian, which means like me, he also has to put up with this malarkey:
    My fuel buying game has nothing to do with how far I can get on a tank and everything to do with trying to second guess the fuel distribution cartel and buying petrol on the day I feel is nearest to the low point. With the c this means I rarely get below half on the display and I think I may have once seen two bars, but only briefly.
    On the flipside, as per the graph, fuel prices did their thing and soared in Melbourne on Saturday. When you find yourself in this sitatuon, if you are thinking of filling, clearly there is some encouragement to delay it where you can. I'm wondering if this was a contributing factor. Then again being "notorious for driving my cars when the fuel gauge is in the red" is clearly something many have warned must be given up when you own a Prius.
    mertechperformance likes this.
  5. Mendel Leisk
    41,260
    Personally I fill up when there's a gas station convenient and the tank is anywhere below 1/3 tank remaining. It's simple, keeps you out of trouble. And I find the OP's attitude exasperating. But all that aside:
    Running out of gas should not break the car. Toyota must have set the programming up with a battery limp mode that's overtaxing the battery.
    mertechperformance and NDcowPoke like this.
  6. RRxing
    RRxing Senior Member
    2,542
    1,817
    NEPA
    Ah, the old "How low can you go?" conundrum...
    THIS IS NOT A LIMBO CONTEST!!!!
  7. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    You would prefer programming that put the driver at risk? I think it is more appropriate to sacrifice the car.
  8. Zythryn
    Zythryn Senior Member
    6,408
    4,407
    The car is showing you that it is running out of petrol and you refuse to fill it.
    You then are surprised when it stops?
    You work for the NYT don't you?
  9. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Running a car completely out of gas is also bad for the fuel pump. I'm not really sure how you could have run out and then blame it on the car... after the beep and flash of bar 1 you get 1.5 gallons. For me this has been a consistent 50 (as I don't want to run out of gas) miles after the beep. So you ignored the flashing bar on the fuel gauge for at least 50 miles (depending on your mpgs). Nobody is going to feel sorry for the cars "flaw" that you tried to exploit and failed.
  10. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    OP brodered a Prius. The only thing that's missing is a photo of the car on a flatbed as it is being towed to a gas station.
  11. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    Ignoring warnings is nothing new.
    All we can do is inform owners of the consequences of their choice.
  12. 2015Prius2
    2015Prius2 Member
    150
    67
    I think you've upset the all mighty prius nerds, they spend every waking minute on this forum waiting for someone to jump on and call them dumb. So much for you having an opinion. It's the typical pompous attitude that gives prius drivers a bad name ( the feeling that they are better than others)
  13. Zythryn
    6,408
    4,407
    Nothing pompous about it and it has nothing to do with driving a Prius.
    Driving until you run out of fuel is just plain stupid. Especially when you have a reserve (battery) do get that last half mile or so.
    Doesn't matter if you are driving a Prius, an Audi, a Hummer, or a pure EV.
  14. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    Let's get this straight: OP deliberately drove the car until the gas tank went dry and then wondered why the car didn't go. Rocket scientist is needed here.
  15. 2015Prius2
    2015Prius2 Member
    150
    67
    And that gives you the right to judge somebody and say they are stupid? I love the mentality of ganging up on someone because you disagree with them.
  16. Lutchenko
    307
    211
    So by the same token someone drives their car ignoring the fuel low warning until it stops. Does that give them the right to blame the car?
  17. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    I think it's because the OP was blaming everyone but themselves. Running out of fuel is totally avoidable and blaming a car is not the wisest move.
    If they'd come on saying they'd done a dumb thing and might have accidentally damaged their car, they might have had a different response, but blaming everyone and everything else just rubs everyones back up.
    Harsh but true.
  18. 2015Prius2
    2015Prius2 Member
    150
    67
    Ok so I understand correctly, you are defending an inanimate object and in turn calling a person stupid?
    I think I understand now...... Carry on
  19. kenoarto
    398
    Chicago, IL
    Prius is a very smart car. OP not so much!
  20. Lutchenko
    307
    211
    As opposed to doing something stupid and blaming an inanimate object yeah lol
