Ran out of fuel AND battery!!
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Yuval Legendtofski, Mar 9, 2013.
  1. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    A lot of those 4 pages became a meta-discussion about the thread itself... as a discussion forum it is fair to expect people to respond to this meta-discussion as well.
    In my view there's a lot of tone on BOTH sides that has been unnecessary and unhelpful.
  2. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    True, there has been plenty of bashing. But he called folks smug on page 1...
    SquallLHeart likes this.
  3. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    When my Prius broke down the other month the recovery guy sent by Toyota wouldn't even bother trying to investigate the problem.
    His thinking went along the lines of; if it's a hybrid we flatbed them to the dealers.
  4. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    Sure, why not?
  5. Rainking
    Rainking Member
    164
    New York
  6. ufourya
    ufourya We the People
    1,258
    336
    42
    You may not have noticed that YOU are a Prius owner.
    MOST hybrid vehicles act differently from non-hybrids when they run out of fuel to protect the traction battery from damage. (Read article linked below.) So blaming your car or Toyota for your own ignorance of this fact has resulted in what you characterize as knee-jerk reactions from smug Prius owners. I've owned lots of cars other than Prii and I've been smug most of my life. :)
    What Happens When Your Hybrid Runs Out Of Gas?
    In point of fact, your car was smart enough to protect itself from YOU.
  7. ufourya
    1,258
    336
    42
    fuzzy1 likes this.
  8. RocMills
    RocMills Active Member
    789
    277
    Las Vegas, Nevada
    Neither, from what I read, was the car PROPERLY refilled with the recommended amount of fuel before anyone attempted to restart it. I am not smug about owning a Prius, but I did read the manual before I set about using the car on a regular basis, because I had never driven, let alone owned, a hybrid before - and I learned enough to tell the others who might drive my car to never run it dry or fully drain the EV battery.
    As others have stated, I think what set folks off was the fact that the driver was blaming the car for what was obviously an operator error.
    kenoarto, cknfts, sfv41901 and 2 others like this.
  9. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    You've taken a lot of heat within this thread.
    But it's not because of what happened to you, it's because of your attitude and viewpoint about what happened to you.
    Within your original post you make some statements that simply are not valid or correct.
    Your honest admission that you are notorious for running cars when the fuel gauge is in the red, well? Prius owners are going to tell you this is NOT a good idea with a hybrid, better change that habit.
    " I mean SHEESH! isn't the battery meant to give you the extra km or two? "-Quite frankly...no, the battery isn't designed to allow you to run out of gas.
    " That pretty bad design logic when the car runs out of fuel and battery that there is no redundancy or fail-over"
    -What vehicle hybrid or otherwise gives you a "fail over" if you totally run out of fuel? As far as I know, all vehicles stop running when they run out of fuel, hybrid or otherwise. If I run my Honda Fit to empty? The engine is going to stop. I am not then going to complain that Honda didn't provide a secret extra gas tank, or a magical process that allows me to drive further without fuel.
    "With all the 'smart electronics' you'd think the electronic fuel gauge would have a FINAL warning (something like 'less than 5km please refuel'), much like the battery on an i-pad! I mean lets be honest here, the Prius is like a computer with wheels on it, I mean it fires up like a bloody Mac or Laptop FFS!!"
    -Again, the vehicle is designed with a FINAL warning...it's that bottom fuel bar that was flashing. That would be that final warning. I think most people in this thread were trying to tell you...just don't let that happen. Your admitted practice of driving a vehicle to the "red" or low? Is not a good practice. Not a good practice for any vehicle, especially not a good practice with a Prius.
    And then finally...
    " maybe Toyota will issue a firmware update to fix this problem!!!"
    What problem? The vehicle worked and behaved exactly as it should. Basically, YOU allowed YOURSELF to run out of gas, thought that somehow driving a Hybrid with a battery would allow you to drive further...not true, and not a good idea. Then you became frustrated when this electronic, gas and battery vehicle did not simply start right back up after you added fuel. Again people within this thread tried to tell you why it did not start right up, and outline the exact procedures needed to restart in your very avoidable situation.
    Did you take too much heat within this thread? Probably. From myself and others. But it's blood in the shark infested waters when YOU make a mistake, then try to blame it on the vehicle.
    It's too bad the vehicle does not behave in the manner you for some reason believe it should. But the further truth is The Prius, for all it's electronics, Battery and Hybrid reality is NOT "only" a computer. It is a automobile and a vehicle. And if you can find ANY vehicle that is designed to purposely allow you to run out of gas without consequence? Well good luck with that.
    kenoarto, Matt H, cknfts and 8 others like this.
  10. fuzzy1
    10,412
    RocMills likes this.
  11. Mendel Leisk
    41,347
    ^ In both of the above links they talk about avoiding pushing or flat towing the Prius, that it might cause the car to generate excessively. AFAIK, with the car off there's no way to turn the front wheels, it's automatically in Park.
  12. patsparks
    10,664
    567
    Adelaide South Australia
    Put the car in accessory mode by pressing the power up button twice with foot off the brake, select neutral. True for Gen II Prius.
    kenoarto and Mendel Leisk like this.
  13. RocMills
    789
    277
    Las Vegas, Nevada
    The C does not have a power button. Higher trim levels may have push-button start, is that what you mean?
  14. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    for a packages 3 and 4 in the US... there's a power button.
    it wouldn't be called a "push-button start".. though it accomplishes the same thing... but yes.. it's more politically correct to call it a "power button"
  15. RocMills
    789
    277
    Las Vegas, Nevada
    See, "power button" to me would be something along the lines of the EV mode button or the ECO mode button - putting the car into a stronger or more powerful mode. I would never consider calling a push button start to be a power button, I'd call it the start button.
    It does seem a contradictory way of thinking, though, since it is clearly the power button I press to turn on my computer. LOL
  16. Rob.au
    960
    441
    Sydney, Australia
    i-Tech
    ...and it actually says "POWER" on the button. :)
    patsparks and RocMills like this.
  17. SquallLHeart
    826
    247
    San Jose, CA
    lol.. yes... that too :LOL:
  18. RocMills
    789
    277
    Las Vegas, Nevada
    Hey, don't pick on me! I only have a 2, haven't even seen the interior of the higher trim models, so how the heck would I know! ;-)
    I still think it's confusing to have a power button that does not take you into "power" mode. It should be the "on" button or the "start" button... oh, never mind, I'm just being silly...
    ztanos likes this.
  19. Yuval Legendtofski
    Yuval Legendtofski Junior Member
    When I was in my precarious state, I remember there is actually an old-school 'analogue' key I was given, unfortunately it was at home, I though, shit, maybe the key will fire up the engine like old times, alas not to be, computer 'power' I mean 'car ignition' button it is.....
  20. Rob.au
    960
    441
    Sydney, Australia
    i-Tech
    Sorry, I just couldn't resist. :)
    You are quite right of course... it's not so bad for us with the c as there is no "Power mode", but it is a bit silly to have Prii with both a Power button and a Power mode which are two completely different things.
