Ran over a dip too fast
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by poormanstesla, Sep 4, 2017.
  1. poormanstesla
    poormanstesla New Member
    Los Angeles
    I wasn't paying attention and didn't see a dip in the road. I went over it too fast and the bottom of my car scraped the road. Immediately afterward, I smelled some burning so I quickly pulled over and inspected the bottom with a flashlight. As far as I can see, there's no visible damage or leaking. After I got home, I took a closer look and the front underside had bits of of the road stuck onto it.
    Is there anything I should be on the lookout for? Which parts should I take a closer look at?
  2. StarCaller
    StarCaller Senior Member
    1,246
    697
    Cedar Crest, NM, USA
    I bet everybody here had this experience already; for normal you will just see a view scratches on the plastic cover/
    if you don't see nething else, you're ok/
    the burning smell?
    might be a coincidence with something else....
  3. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    The only damage that would occur is with the plastic panels that line the bottom of the car. There are no mechanical parts low enough to be damaged on a "flat" road. Over large rocks, that's a different matter.
    When the car scrapped the road that would generate the burning smell. Friction does that. ;)
  4. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    Road hazards. :p
  5. poormanstesla
    Los Angeles
    Thanks for the help everyone!
