Random Engine Shutdown/Low Power
Discussion in 'Gen 2 Prius Main Forum' started by BuckleSpring, Apr 11, 2026.
  1. BuckleSpring
    BuckleSpring Member
    77
    38
    United States
    Ordered 1-4, left to right. Nothing particularly weird, usual small amount of residue from oil burning as to be expected, but not bad considering they're ~50k miles old (If I'm remembering correctly).
    As for mileage, it's part of the 299,999 club, probably around 320-330k if I had to guess.
  2. Brian1954
    Brian1954 Senior Member
    2,684
    1,072
    South Central PA, USA
    Thank you for the picture of the spark plugs and the car mileage. What brand and type of spark plugs are they?
  3. BiomedO1
    BiomedO1 Senior Member
    4,598
    2,412
    Left Coast
    2-4 looks a bit ashy, so burning lean. FWIW; they should look closer to #1; but it could just be the lighting of the picture. Are those plugs iridium and are those electrodes edges supposed to be rounded like that? I don't see the wire, unless they just put a drop of it on the electrode tip. I'm used to seeing a small iridium wire sticking out.
  4. BuckleSpring
    BuckleSpring Member
    77
    38
    United States
    They're Densos, I couldn't tell you the PN#, my brother changed them 50k+ miles ago when he was borrowing the car for a couple of months.
    It's just the lighting, they're all identical in person.
    Either way, I don't get a change in misfire count in the live data at varying load/rpm, so I don't think the plugs are the particular cause of this issue.
    Brian1954 and BiomedO1 like this.
  5. dolj
    dolj Senior Member
    8,646
    4,397
    Wellington, New Zealand
    To my eye, that gap is too large. For 50,000 miles, those plugs look burnt out, so I wouldn't be surprised to learn that the 'iridium' tips were not iridium.
    I've pulled real Denso iridium tips after 100,000 miles, and the length of the tips looked almost new. I checked them, and they were still in spec. You need to check the gap with feeler gauges, they should be 1.0-1.1 mm, max 1.2 mm (I can't remember the old units off the top my head, sorry.)
    Brian1954 likes this.
  6. BuckleSpring
    BuckleSpring Member
    77
    38
    United States
    No clue if they're iridium or not, but I agree with you that they're probably not judging by the electrode. However, I swapped them with some other plugs I had on the shelf and it made no difference to the engine running condition.
    I have it on the lift and I'm going to drop the exhaust out this evening to see if it's a catalytic converter issue.
  7. BuckleSpring
    BuckleSpring Member
    77
    38
    United States
    I undid the flange up by the cat inlet and laid it down on the subframe, so I could take it out for a little drive around the farm for a test.
    Power went back to normal, didn't fall on its face or try to die. So... Looks like one of the cats has a restriction, and I'll deal with "fixing" that this weekend.
    Still no clue as to why this would lead to the lean code or the engine failing to start, but I'll take care of this and see if it returns in the next week or so.
  8. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,014
    NJ-USA
    Well, if the lean code was "false" (ie, something like a faulty Air Fuel sensor), then the ECM would incorrectly compensate by adding (too much) fuel. This could result in carbon soot deposits clogging the cat.
    If the exhaust is restricted, then the engine can't pump air like it should - which causes low power, rough run, & no start.
    Moderate to severe misfire can dump lots fuel and air into the catalytic converter, causing the cat to overheat and breakup (leading to restriction).
  9. BuckleSpring
    BuckleSpring Member
    77
    38
    United States
    Since it's been a few weeks, just thought I'd post an update.
    I was able to pull the exhaust system off of the car and take a look. The front/upper cat had blown all of its guts out, which was sitting on the secondary cat. Only one honeycomb in the entire second cat had any flow through it whatsoever.
    After "fixing" that issue, the car has been running fine for the past ~800 miles or so. Engine startup/shutdown is basically un-noticeable, no lean codes, no misfire codes, power is better than it has been in a very long time, and fuel economy has been pretty steady at ~47MPG.
