Random locking and unlocking please help
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Joey verstraete, May 9, 2017.
Tags:
  1. Joey verstraete
    Joey verstraete New Member
    Hi so my 2008 Prius is randomly locking itself and unlocking itself while it's off and while it's off and a door open it beeps as if you tried to lock the doors while a door was open ive tried disconnecting the battery for a few minutes then reconnecting but that did not work can someone please help me out here
    49,488
    welcome!
    could there be a fob hiding in there somewhere?
    also, have you checked the 12v health?
  3. dolj
    dolj Senior Member
    7,652
    3,866
    Wellington, New Zealand
    Sounds like you may have a lock button stuck in the "on" position on one of your remotes. You can search the Gen II forums for: stuck button on remote FOB for further info on how to go about fixing.
    SFO likes this.
  4. Joey verstraete
    It continues beeping while both fobs are out of range
  5. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    As mentioned, check the 12 V battery in the car.
    This also could be caused by one of the manual lock buttons on the doors stuck in a middle position.......as in, a failing door lock actuator.
    Sit inside the car and use the FOB to lock and unlock a few times.....while watching and listening for the manual buttons to move.
  6. Deogratias
    Deogratias Member
    37
    42
    I had a jeep several years back that started randomly locking and unlocking for no apparent reason. Even had it towed to the dealer because I assumed it meant there were serious electrical problems. It turned out to be just the battery.
    I'd replace your 12V battery and see if that fixes it.
