Range Anxiety
Discussion in 'Prime Fuel Economy & EV Range' started by m8547, Dec 13, 2018.
  1. m8547
    m8547 Senior Member
    950
    628
    Colorado
    2018 Prius Prime
    I rolled up to the charger with 0.1 miles of EV range left this morning. I was actually surprised I made it since it's 28 degrees (F) outside.
    52,400
    i love when that happens, but hate when the ice kicks just as i get there.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    You do realize that the gas engine MUST RUN some to keep the fuel fresh......right ??
    If it doesn't run much in "normal" use, eventually it WILL run some no matter what you do.
    So why not just let it run some during normal use and then don't fret about it ??
    Sometimes you can be your own worst enemy.
    52,400
    if you don't own a plug in, you'll never understand
  5. m8547
    m8547 Senior Member
    950
    628
    Colorado
    2018 Prius Prime
    It's mostly just a silly thread where people can share stories of their self-imposed range anxiety.
    The engine runs plenty. I usually go through a tank of gas about every 1200 miles. Probably 1/3 or my miles are in HV mode. Otherwise I would have bought a pure EV. I've never seen it run just for the sake of keeping fuel fresh, because it runs for lost of other reasons first.
    I try to keep the number of cycles on the engine low. Warming up probably isn't great for it, but once it's warm, might as well use it. If it had switched over to HV in the parking lot, it would have had to go through a warm-up cycle while parked, which feels like a waste (even if the energy goes into the battery). Or I could have shut it off before it warmed up, but that would leave condensation where it shouldn't be. I considered switching to HV mode a few miles away, but with 10% battery left and 2 or 3 miles to go I thought I might be able to make it.
    But the engine gets used so little compared to any other car that it will probably last forever no matter what I do.
    Arctic_White, m.wynn, jaqueh and 2 others like this.
  6. sam spade 2
    7,035
    2,804
    2017 Prius c
    Oh I understand perfectly.
    People these days seem to obsess over tiny details of crap that doesn't really matter........but then give little to no time in researching things that can mean life or death.
    The thing I don't understand is WHY ???
    jaqueh likes this.
  7. bisco
    52,400
    enjoyment. you need balance
  8. sam spade 2
    7,035
    2,804
    2017 Prius c
    OK, I understand that.......if they really are spending time on stuff that really matters too.
    Do you also have 72 thousand posts on any forums about something that really matters ??
    (Sorry, couldn't resist.)
  9. bisco
    52,400
    no problem. this is my only forum. i don't bother much where i can't help make a difference, like fhopol. it's just hot air
    m.wynn and HPrimeAdvanced like this.
  10. sam spade 2
    7,035
    2,804
    2017 Prius c
    A journey of 1000 miles begins with one step.
    WTH is fhopol ??
  11. bisco
    52,400
    i have concerns about telling you, i fear for your sanity
  12. Mendel Leisk
    41,925
    The one reason I can for PIP range anxiety: if the engine comes on say within a block of your destination. Firstly because it's frustrating, and secondly because it the cold-start-and-almost-immediate-shut-down scenario, that seems to lead to engine shake/knock at the next start-up.
    I wonder if anyone with a PIP has that cold-start shake while they're underway, when they ran low on charge?
  13. bisco
    52,400
    not me, but i never shut down until the engine does
    i was hoping prime would have the ford button that allows an extra draw on the battery every so often for just such instances
  14. m8547
    m8547 Senior Member
    950
    628
    Colorado
    2018 Prius Prime
    That would be nice. The Prime saves enough charge to keep the car going while the engine warms up. Sometimes that's enough to get to a charger. Or often the case if I park at a trailhead in the mountains, that would be enough to get going down the hill.
  15. bisco
    52,400
    Doesn’t Really matter once the engine has started, does it?
    Arctic_White likes this.
  16. sam spade 2
    7,035
    2,804
    2017 Prius c
    Now that's not a nice remark.
    HPrimeAdvanced likes this.
  17. bisco
    52,400
    how so? just trying to protect you
  18. bisco
    52,400
    ironically, it just happened to me. took my wife for her eye checkup. i thought i had plenty of charge, but on the way home, had less miles left than expected. started slowing down, took a side road, came up my street with .3, .2, then .1 way too far away. somehow nursed her home and into the garage, hit the power button quick, before the engine fired!:cool:
    Arctic_White, m.wynn, benagi and 3 others like this.
  19. El Dobro
    El Dobro A Member
    7,093
    3,271
    Fred's House of Politics. Beware!
  20. bisco
    52,400
    i take no responsibility
