Range decreases fast
Discussion in 'Gen 4 Prius Fuel Economy' started by bigtoniaguiar, Feb 15, 2019.
  1. bigtoniaguiar
    bigtoniaguiar New Member
    Rio de Janeiro - Brazil
    I am Brazilian and I have a Prius 2017, I am in doubt. I put 20 liters of gasoline and the Prius shows 520 km of autonomy, but the same use of electric motor of automatic driving, for example: I drive 20 km using more electric motor than the gasoline engine and the autonomy instead of reducing to 500 km to 480 km, I do not understand
    #1 bigtoniaguiar, Feb 15, 2019
    52,784
    congrats and welcome!
    you're going bout it all wrong. hybrids aren't meant to overuse the battery. the battery is there to collect what would be wasted energy, then use it as necessary.
    just drive it for a few tankfuls, and measure your mileage at the pump.
    then, if you want to improve your mileage, learn how to drive a hybrid for higher mileage by searching youtube for instructional video's.
    use search terms such as 'hypermile' and 'pulse and glide'. don't worry about km per tank or autonomy.
    all the best!(y)
    bigtoniaguiar, krmcg and jerrymildred like this.
  3. bigtoniaguiar
    my battery runs out fast, I can not complete the battery charge, I can only get up to 80% of the maximum charge and it ends up very fast. If I leave the gasoline engine turned on to give maximum battery power, it will not compensate for the gasoline it consumed
    because the battery charge runs out fast
    52,784
    Then you need a new battery.
    Do you have any idea what you’re getting for mpg’s?
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    Sorry, but this is very confusing. Is it a 2012 or a 2017? Your post says 2017 but your profile says 2012.
    Either way, leave that EV button alone. You're killing your mileage and reducing the lifespan of your traction battery. EV with a regular Prius is just so you can move the car a short distance without needing to start the engine. It's not meant to be driven in EV mode except in rare cases. Otherwise, just drive it and ignore the EV button. The computer will almost always decide when to start and stop the engine way better than we can.
    It's normal for the battery level to have two unfilled bars. Like this picure provided by @john1701a:
    That's where the car wants to maintain the charge. It may go up or down a little, but will always come back here.
    bisco and bigtoniaguiar like this.
  6. bigtoniaguiar
    Okay, you're right, I'll drive more quietly.
    thanks for the tip
    jerrymildred and bisco like this.
  7. bigtoniaguiar
    I have my Prius a short time and I look forward to driving in EV mode. I'll drive more quietly.
    thank you
  8. bisco
    52,784
    i also liked ev mode so much, traded my hybrid for a plug in hybrid. the plug in charge lets me drive 12-15 miles around town, which is a lot of fun. when it runs out, it becomes a regular hybrid.
    yours is too new to trade, but if you enjoy ev driving, consider some sort of plug in down the road.
    jerrymildred likes this.
  9. jerrymildred
    11,517
    14,164
    Tampa, FL
    Great advice, @bisco!!
  10. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Range to empty is based on your current driving style. If it says 520 km to start then you drive 20 km and it says 480 km, it just means you are not driving as economically as you were before it said 520 km.
    jerrymildred, krmcg and FuelMiser like this.
  11. Colin Jones
    Colin Jones Member
    99
    174
    Aberdeen/UK
    Business Edition
    ...not just driving style of course, but terrain, weather, traffic etc all have an effect. So for example, you may have done 50 miles on flat ground, and then start climbing mountains - at which point you're going to see less mpg as the engine has to work harder.
    kithmo likes this.
