Rapid clicking (vibration) from MFD when starting
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bananastand, Feb 12, 2022.
  1. Bananastand
    Bananastand New Member
    Phoenix
    2011 Prius. Everytime we start the Prius we hear a rapid clicking coming from the dash. The clicking (sounds like a really fast relay, or slipping gear vent door gear?) Lasts for4-5 seconds, when all systems would go through diagnostics, self checking when car is first turned on. I can feel a vibration during the clicking strongest when touching the MFD screen. What could be clicking behind the MFD? Could it be the MFD itself? The clicking does not occur at any other time other than initial start.
    Things we have tried: disconnected battery for an hour. When reconnecting battery, the sound/clicking occured again.
    Cycled through all air conditioning vents with heating and cooling. No clicking occured, and everything worked as expected. I was thinking it could be the mixture valve, but I stuck my hand and head down there and I did not feel the vibration or hear the clicking coming from under the dash.
    Has anyone experiences this, or have any ideas? Thanks!
    49,430
    it sounds like a relay trying to close. can you hear anything under the bonnet?
    i would test the 12v health, free at most auto parts stores
    PriusCamper likes this.
  3. PriusCamper
    PriusCamper Senior Member
    11,091
    4,514
    Pacific Northwest, USA
    Need a better description here... "clicking" is too vague... And as @bisco says, we need you to be sure it's coming from the dash and not the engine compartment for us to help you with a repair.
  4. Bananastand
    Phoenix
    Thank you guys! I'm working on getting video of the issue as I'm sure it will do better justice than be trying to describe the issue.
