Rat ate my wiring
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jaskam, Sep 26, 2022.
  1. Jaskam
    Jaskam New Member
    Cleveland, oh
    Looks like a rat had a nice lunch in my car .
    I would like to know what wires are on this harness and best way to fix it?
    Suddenly I am getting high coolant temp warning and no windshield wipers.
    2010 prius ll
    Thanks
  2. ChapmanF
    18,894
    I believe that branch there is only to the windshield wiper motor. If that's all the rat ate (considerate rat!) you have lucked out ...
    ... except that you had better look into the high coolant temp warning as a likely separate problem, because rat-eaten wiper wires will not have caused that.
  3. Jaskam
    Jaskam New Member
    Cleveland, oh
    Nice to know. Should be pretty easy fix. Now, more troubleshooting on hifg temp.
    Thanks
  4. Tombukt2
    Tombukt2 Senior Member
    13,765
    2,491
    Durham NC
    I have that all unplugged for my engine change I'm going to have to splice all that together unless you're going to change the whole harness out. I wouldn't want to do that.
  5. Jaskam
    Jaskam New Member
    Cleveland, oh
    Splicing is definitely easier. thanks
  6. ChapmanF
    18,894
    Looks like the rat was considerate enough to only eat a branch of the harness containing the four wires that go to the wiper motor.
    Splice four wires, or replace $4097.46 engine bay wiring harness ... decisions, decisions ....
  7. Jaskam
    Jaskam New Member
    Cleveland, oh
    Hmmm. That is pretty easy to decide.
    Thanks
  8. Tombukt2
    13,765
    2,491
    Durham NC
    Buy an Amp plug assy. And pin tool have here on desk here in shop in 2 4 8 12 wire versions left over from rewiring a Mercedes 190 sl coupe like 57 model .years ago like 89. Good luck
    Jaskam likes this.
  9. ChapmanF
    18,894
    If there is enough slack to just lose the half inch or so in length, a Toyota-esque repair would be with parallel splice barrels and sealant-lined heat-shrink sleeves as described here.
    Toyota doesn't seem bullish on the more-commonly-available butt splice barrels, but those could be an option if the parallel splices would shorten the wiring too much. Still with the gooped heat-shrink, of course.
    You might also consider wrapping some of your wiring in rodent tape.
    Grit likes this.
  10. Jaskam
    Jaskam New Member
    Cleveland, oh
    That should work.
    Thanks
