Rattle behind steering wheel within dash when hitting bumpy road
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Misplaced10mm, Aug 15, 2021.
  1. Misplaced10mm
    Misplaced10mm Junior Member
    2018 Prius
    I have a 2018 Prius V (Canada only release, it's same as the 2017 V in the US). And a few weeks ago it developed an annoying, metallic rattle behind the steering wheel.
    When I removed the paneling (all except the top most part since it's connected to the A column panel) the rattle was definitely louder. The rattle is coming from deep within the dash.
    The rattle occurs whenever I hit bumpy roads at higher speeds. I took apart the surrounding paneling and did the following troubleshoots:
    • Tightened the Intermediate Steering Shaft bolt. It was already locked down tight
    • Took apart the paneling beneath the steering wheel and tightened every accessible bolt
    • Tried tightening and holding down the ducting while driving as explained in this old post. Noise is NOT the ducting because even when I held and secured it the noise persisted
    Any guesses?
  2. Air_Boss
    Air_Boss Senior Member
    3,939
    1,076
    New Yawk
    It's new. Take it to the dealer and have them sort it out.
    Probably a 'spare part' that was dropped and lodged itself in the dash during assembly.
  3. Misplaced10mm
    2018 Prius
    Problem solved- the rattle was caused by a loose junction box. Probably from an electronics project from a few years back. Tightened it down and rattle is now GONE.
