Rattle clunk from front end
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mfa-prius, Jun 29, 2010.
  1. wingfeathers
    wingfeathers Junior Member
    16
    If it helps future visitors to this discussion, I had a similar issue which I was finally able to resolve! I had the vehicle inspected by technicians twice, who couldn't find anything loose with the suspension or steering. I poked around and found two possible sources: the plastic wheel well liners and the heat shield towards the front of the cat. Each of these items were slightly loose when I pushed on them. I placed some rubber padding between the liners, and for the heat shield I installed new fasteners. My clunk is gone. Hope this helps someone!
  2. dolj
    dolj Senior Member
    8,645
    4,395
    Wellington, New Zealand
    The problem with doing two things at once is not knowing which one fixed the problem.
    If I was a betting man I'd wager that it was the loose heat shield rattling.
