Rattle During SoCal Cold Start
Discussion in 'Prime Main Forum (2017-2022)' started by geguia, Nov 19, 2018.
  1. geguia
    geguia Active Member
    210
    108
    los angeles
    I'm experiencing a rattle in the center dash during cold starts - cold being in the low 50s.
    Pretty annoying.
    No issue in the afternoon or on sunny mornings.
    Ideas where this is coming from?
  2. huskers
    huskers Senior Member
    2,549
    2,488
    Nebraska
    I'd kill for 50 degrees.
  3. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    Not sure if same or not, but I had a rattle in my PRIME premium coming from the center dash, but it was not related to temperature or ICE coming on. It was low ticking type noise when car is in motion at any speed, but it came and went on its own. AC on or off did not make any difference. Took the car to a dealer, and they found instrumental module touching nearby plastid part causing the noise. They did not replace anything, but placed some foam material in between. Problem solved. It was taken care of under warranty.
    geguia likes this.
  4. geguia
    210
    108
    los angeles
    Thanks - Toyota techs are not very helpful.
    It's very different from my previous experience as a bmw owner.
  5. Salamander_King
    11,024
    8,978
    New England
    Is your car still under warranty? If it is, it maybe worth the visit to a dealer. Taking off the dash was not something I would be able to DIY easily, so I took advantage of the warranty while I could.
