Rattle (Flutter) noise from Transmission at high RPMs
Discussion in 'Gen 2 Prius Main Forum' started by way2coolwheels, Jan 22, 2020.
  1. way2coolwheels
    39
    42
    Well, I haven't been on this site for about a year. And the good news is that it's because the Prius has been performing great! My commute part of the time is 200+ miles, for several weeks at a time, so I've accrued 15K miles since the engine swap and fuel tank replacement. But, now I have a new problem, a loud noise from the transmission (transaxle)
    At first I thought it was valve train noise, sounds like noisy lifters. However, if that were the case, it would occur all the time. This only happens on acceleration and at high engine RPMs. So I got out my "engine ear" and placed it in various places under the hood. The engine sounds normal, but the noise is quite pronounced when the microphone is aimed directly down at the transaxle.
    So, before I go about the task of replacing the transaxle, I thought I'd ask if anyone else had the same problem.
  2. PriusCamper
    PriusCamper Senior Member
    13,455
    5,430
    Pacific Northwest, USA
    Put a big super strong magnet on the drain bolt for your transaxle and then after driving the car for a while drain the fluid and see if you catch any larger size chunks of debris. Then replace fluid and see if the noise changes much... Or at least that's what I'd do first... As in going from least expensive to most expensive repairs. The fact you don't have any warning lights and you're already starting to figure it out raises your chances of success.
    way2coolwheels likes this.
  3. magnumrtawd
    magnumrtawd Member
    306
    72
    Toledo,Ohio
    Check the shield on the exhaust. It may have come loose and now rattles.
  4. way2coolwheels
    39
    42
    Thanks for the suggestion, I doubt it's the heat shield, but it's worth a double check.
  5. way2coolwheels
    39
    42
    Well, if there ARE metal pieces, it's gonna need a transmission anyway. I forgot to mention, this one has 260,000 miles on it! Nothing good lasts forever!
  6. PriusCamper
    13,455
    5,430
    1/4 million miles isn't much for a Prius, if there was 1/2 million miles I'd agree... Likewise, if there was warning lights and error codes and metal pieces, yes, I'd agree. But if there were just noises and some debris in there and you got it out before any further damage was caused you'd save a ton of money and your car would back to normal in a matter of hours.
  7. magnumrtawd
    magnumrtawd Member
    306
    72
    Toledo,Ohio
    The reason I mentioned the heat shield is I just found my 2010 had that problem. but, I didn't notice it until parked on a windy day. It sounded like loose sheet metal banging on something! The nuts were severely corroded.
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Dump the fluid and check the dump bolt magnet. Then put the fluid in a big mouth container and put it in the sun and see if you see any metal in it.
    There is a bearing that sometimes fails and also It may be the chain is going bad from lack of fluid maintenance. Seen a few chain failures here but mostly rare. Its mechanical so thats why its not throwing a diagnostic failure code.
    Sometimes the inner cv joint fails and it beats up the seal where it enters the trans differential and the trans fluid leaks out that bad seal.
    Whatever it is you need to check the fluid asap.
    PriusCamper likes this.
  9. way2coolwheels
    39
    42
    Well, I changed the transmission fluid when I did the engine swap about 15-20K miles ago. I'll drain it again and see what shows up.
  10. PriusCamper
    13,455
    5,430
    I suspect that with doing the fluid that recently the likelihood that it will be clean enough to run through a filter and re-use is high...
