Rattle from the passenger side dashboard
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Frankblack0503, Nov 3, 2009.
  1. Frankblack0503
    Frankblack0503 New Member
    64
    Belgium
    Tom,
    I also removed the little side window vent and the passenger's A/C vent due to ticking noises. It must be done carefully or guff marks can result, but they do extract forwards with several anchor clips revealed once extracted. What I did was put some spray silicon lubricant in a large bottle cap and then used a Q-tip to apply it to each clip and along all the seams in the dash where the vents make contact. That way, no silicon was visible when I put the vents back. I did the same for the driver's side A/C vent too. It seems to have helped, but once one rattle is quieted, others become apparent! It is maddening but one by one, I will try to solve them.
    Could you provide some pictures of that ?
    One pic says more than so many words...
    Thanks !
  2. phoenixgreg
    phoenixgreg Senior member
    1,157
    295
    66
    Phoenix
    Extraction needs to be done carefully or you will guff the plastic. I started with the right-most edge of the upper vent nearest the passenger door prying with a screwdriver to begin the removal. Once you get movement, you can work it the rest of the way out. Do the same for the lower vent - start at the rightmost edge.
    Here are some shots:
    1) Shows exposed opening in dash after vents are removed. Use a Q-tip soaked in silicon lubricant to coat the ridges just around where the vents seat. Be careful not to get the silicon on areas that will be visible once the vents are re-installed. It can stain the plastic so it should only go on surfaces that will be covered once the vents are back in place. That should eliminate any ticking from the vent housing rubbing on the dash.
    2) Pics of the vents removed (forward view)
    3) Pics of the vents removed (rear view showing mounting clips). Also put silicon lubricant on each clip and along the backside where the edges meet the dash.
    4) Recently discovered the upper right vent is composed of 2 pieces! There was no foam to buffer the vent tube from rattling so I added some shown below. It helped get rid of the little noise coming from there (lower left in pic below).
    Reverse the process to re-install. Start with the lower vent - press in place. Then the upper vent. Be careful and good luck
  3. tobag
    tobag New Member
    Yes, I have the totally annoying right side dash rattle. Dealer unable to fix. Interesting that as it is in for the last try, the Prius rental car the dealer provided ALSO has the same rattle. Have had other minor rattles; center console, door handle, driver side front window. I am considering arbitration with Toyota.
  4. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    I had this noise......seem to come from the speaker grill...dealer tightened door jamb bolts......took care of my noise
  5. CarmelPrius
    CarmelPrius At 1 mile.
    49
    Maine
    I have a 2008 Gen II, that rattles. After reading this, I guess I'll wait to see if things improve - before buying a Gen III.
  6. Crankykentucky
    Crankykentucky Junior Member
    65
    Midwest
    It's just crazy, you know? My 2010 Prius III was perfect until month number three or four, then the rattle/creaking started. So, I didn't even get to put down the issue on the post-sale survey I filled out. No wonder Toyota doesn't know about it.
    It's got to be something really stupid, with my luck. I had a 1958 Chevy with a rattle and I found it--right before I sold it! LOL
  7. Speedracer0284
    Speedracer0284 New Member
    Auburn Alabama
    My dealer found the problem to be a stablizer bar from the front bumper that at high vibrations rattled againsted the plastc in the rear of the dash. Removed the front passenger fender and a small tac weld and the problem is solved. No rattle at all now and the dash did not have to come apart.
  8. Tails
    Tails New Member
    Horsham Australia
    Its a broken clip in the centre of the dash in front of the speedo.
    if you press down on it then it stops.
    My dealer was aware of it and fixed it at 20000km I have now done 37000km and its not back yet.
    They just un clip the top of the dash and put a new clip in the middle.Good Luck
  9. triscb
    triscb New Member
    23
    Harrisburg, PA
    I had a similar ticking noise and they discovered that the problem was the triangular shaped glass was incorrectly installed at the factory.
  10. dirklambert
    dirklambert New Member
    I finally solved the rattle and it is rather simple to solve. I figured when it got warmer and the rattle stopped automatically it had something to do with the expansion or shrinking of the dashboard. Past summer when it was over 20°Celsius there was no rattle. Now it is becoming colder again in Belgium the rattle has returned.
    How to solve: where the front speaker meets the white plastic dash-cover from the little side window you can insert a small peace of felt. Cut a small piece of self adhesive black felt about 1 centimetre in square and stick it to a hard paper card so it has some rigidity. When you now push it in the gap between the speaker and the white plastic just in front of the A-pillar the ticking noise is gone. That's it. The noise is gone and makes driving a pleasure. If done carefully you can make it almost invisible.
    Thanks to the advice I could read on this American site I could solve all the rattles I previously experienced.
  11. Lantec
    Lantec New Member
    23
    BC, Canada
    I tried to do that for my rattle but to have amplified the noise for me.
    My rattle is a bit different in nature though, mine doesn't rattle on bumpy roads but on acceleration. At a certain RPM, about 3/4 way through the ECO bar, it'll start to rattle until I go above that point or lower, which makes it really irritating because I will always hear it no matter the roads are bumpy or smooth. But I think I have found the root of the problem at least. The dealership so far has been useless in trying to fix the noise.
    So when I tried the solution, it make the card vibrate and cause more noise.
  12. phoenixgreg
    1,157
    295
    66
    Phoenix
    Courtesy of "The Critic"...this is the cause of your right side noise:
    "Hey guys,
    It turns out some of the posters were in fact correct on the source of this noise. Toyota just released a TSB on correcting this issue. TSB is # 0064-12, dated 4/16/12.
    The TSB states that the upper fender retainer clips are the cause of the rattle. The fix is to remove the front corner window and remove the fender, in order to replace the clips with an updated part. Warranty time for the job is 3.0 hours.
    Luckily, the only parts required to fix the problem are TWO new clips, part # 53813-47040, and they are about $2/ea. You may also need a "piano wire" for removing the window and some general weatherstrip adhesive.
    This only applies to 2010-11 Prius before a certain VIN. My 2011 is affected."
    Read more: http://priuschat.com/threads/rattle-or-buzz-on-passenger-side-check-here.93716/page-2#ixzz2Bpi0Kko6
  13. Lantec
    Lantec New Member
    23
    BC, Canada
    Thanks! That's exactly the noise! I've been trying to narrow it down forever. I've booked the appointment with the TSB number, hopefully they can fix the problem.
  14. phoenixgreg
    1,157
    295
    66
    Phoenix
    Good luck Lantec...let us know how the repairs went.
  15. Lantec
    Lantec New Member
    23
    BC, Canada
    It's finally fixed! After 2 weeks, the first time around, they didn't book the body shop so they couldn't take the window off but this week, they booked the body shop and they got it fixed. I just told them the TSB number. So happy now. :)
    F8L likes this.
  16. phoenixgreg
    1,157
    295
    66
    Phoenix
    Congrats on the repair - was it covered under warranty?
  17. plam0ne
    plam0ne Ninja
    70
    florida
    Had this problem fixed as well, covered under extended warranty. They also fixed the squeaking brakes when backing up.
  18. Lantec
    Lantec New Member
    23
    BC, Canada
    Yes it was. Overall, it was good. Took a bit over a day but in the end, it was very much worth it.
  19. El Dobro
    El Dobro A Member
    7,102
    3,282
    I decided to check the cabin filter today and look what I found in there. The noise is now gone.
    F8L likes this.
