Rattle In Dash!
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by keymusic, Feb 17, 2017.
Tags:
  1. Prodigyplace
    12,704
    11,846
    Central Virginia
    There is Toyota TSB (Technical Service Bulletin) for this issue. See this thread.
    TSB Issued for Buzzing rattle in dashboard | PriusChat
    RCO likes this.
  2. tucatz
    tucatz Active Member
    501
    417
    Manzanita, Oregon
    Four Touring
    Yes, I know. And I've had the heating duct rattle fixed. This is a different noise, from a different area of the dashboard.
    RCO and Prodigyplace like this.
  3. keymusic
    keymusic Active Member
    211
    113
    Southern California
    I took my radio out and the antenna cable is securely connected to the back of the radio and I didn't see any sort of clip.
  4. tucatz
    501
    417
    Manzanita, Oregon
    Four Touring
    OK, thanks keymusic. Did you look around around inside the dash, wiggle cable bundles, try to find any loose plastic assemblies that willl vibrate? There must be something inside the dash that's rattling around causing this buzzing sound.
  5. keymusic
    211
    113
    Southern California
    I looked a little but not very thoroughly.
  6. dross1167
    dross1167 New Member
    asheville, NC
    I have a 2017 and it's a complete rattle box. Major rattle in the top center of the dash that is getting worse to the point it's almost always there now. Major rattle in the rear hatch when going over sharp bumps. Front brakes are making a continuous clicking sound during slow stops, particularly on hills. Sound is getting more pronounced over time. This car is junk and I've decided to trade it in this weekend.
    tucatz likes this.
  7. keymusic
    211
    113
    Southern California
    What are you going to get?
  8. dross1167
    asheville, NC
    I have no idea at this point. This morning's drive into work was the final straw for me though - it's like this car is literally falling apart after a year of ownership, and I'm a very gentle driver. So disappointing with Toyota right now - one thing for sure it's my last Toyota.
  9. dross1167
    asheville, NC
    My wife has a '15 Subaru Outback. The thing is rock solid after 2 years - no rattles whatsoever, and get's average around 30mpg. Not bad for all wheel drive and the versatility that car provides. I'm not thrilled with the ergonomics of seating etc, but I can live with that. I may just trade for an Outback.
  10. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    That's a bit drastic. Have you considered taking it back to the dealer first for their verdict?
    keymusic and Prodigyplace like this.
  11. bunnydoo
    bunnydoo Junior Member
    16
    26
    los angelea
    what is the black round thing in the center of the air vent right under the windshield ( on the inside of the car)? i feel like the rattle in my 2017 prius is coming from that.
    GlennCocoBad and Prodigyplace like this.
  12. Prodigyplace
    12,704
    11,846
    Central Virginia
    I am curious too. @Elektroingenieur is one of our resident sleuths.
    Elektroingenieur likes this.
  13. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I wonder if you mean the ambient light sensor? This detects when to dim the instrument panels when you pass through a tunnel, or as night falls. Hope that helps.
    bunnydoo and Elektroingenieur like this.
  14. Prodigyplace
    12,704
    11,846
    Central Virginia
    If that’s what it is, mine is partially obscured by an inspection sticker on the windshield. What purpose does it serve in a Trim Two with no auto headlights?
    RCO likes this.
  15. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Not sure if you've misidentified the little dark blister the sits on the top of the fascia in the centre/center position. Even if you don't have auto lights, it will come the instrument lighting as required, automatically whenever necessary. Like when you pass under a wide bridge in daylight, or through an avenue of leafy trees and after dusk.
  16. Prodigyplace
    12,704
    11,846
    Central Virginia
    My dash lights only seem to dim when I turn on the headlights.
    RCO likes this.
  17. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Perhaps that's another limitation on the trim 2, but if I were you, I'd have a look through the settings and see if you can adjust the panel brilliance options.
  18. Prodigyplace
    12,704
    11,846
    Central Virginia
    The brightness can be set separately for headlight on & headlight off. They do not vary based on ambient light.
  19. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I see. I believe I was able to adjust my panel brilliance through settings and even the HUD (which you again don't had) separately. Perhaps you need to pay more for your gas to receive these features. :sneaky:
  20. bunnydoo
    16
    26
    los angelea
    yes, mine is coming from whatever this thing is.... 2017 prius 3 ... on the dash, in the center of the air vent by the windshield.
    Wayleebird and RCO like this.
