Rattle in Front End
Discussion in 'Gen 2 Prius Main Forum' started by Tony714, Dec 28, 2024.
  1. Tony714
    Tony714 Member
    110
    Orange County
    Hey Prius Peeps, I have an ‘08 with 200k on the clock and it has developed a weird rattle in the front end on the passenger side. Only happens when I take off from a complete stop. Any ideas? Sounds very plastic-y
  2. Tombukt2
    Tombukt2 Senior Member
    13,868
    2,520
    Durham NC
    End link/s
  3. Tony714
    Tony714 Member
    110
    Orange County
    Dis you mean Rod End Links?
  4. Tombukt2
    13,868
    2,520
    Durham NC
    Sway bar to strut tube plastic connections that are shiet.
  5. Tony714
    Tony714 Member
    110
    Orange County
    Thank you for that! I will look into that. Is it ok to drive for a little bit like that?
  6. Tombukt2
    13,868
    2,520
    Durham NC
  7. vvillovv
    vvillovv Senior Member
    4,337
    1,519
    NY
    You can find the pair by searching 2005 Prius sway bar links for a few after market suppliers for around $30 + ship
    and you can see the OEM part in a diagram
    Front Suspension for 2005 Toyota Prius | Bam Wholesale Parts
    if above link don't work cut and paste below ( fingers crossed)
    bamwholesaleparts.com/v-2005-toyota-prius--base--1-5l-l4-electric-gas/suspension--front-suspension
    it's #17 in the diagram
