Rattle on cold start, cyl 4 misfire
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tgpa28, Jan 25, 2025.
  1. rjparker
    rjparker Tu Humilde Sirviente
    11,126
    6,981
    Texas Hill Country
    So plugs, coils, injectors and finally a new head gasket did not fix the cold start rattles.
    Wiring is unlikely to be a problem since it runs fine after the cold start. There are continuity and ohm checks in the pdfs but a true intermittent electrical failure needs a 4 - 8 channel digital storage scope like a Picoscope and an experienced diagnostician.
    Honestly everything points to a head gasket leak. A warped head, block or a loose head bolt has caused this sequence of events in the past.
  2. rjparker
    11,126
    6,981
    Texas Hill Country
    #22 rjparker, Jan 26, 2025
  3. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Leak down test must not be an option
