Rattle When Gas Engine Starts
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by antiglare, Dec 23, 2020.
  1. antiglare
    antiglare Member
    79
    57
    SF Bay Area, CA
    I've noticed that on my Prime, when I manually switch over from EV mode to HV by pressing the HV/EV button, the engine makes a rattle like the sound of loose marbles being tossed. This only happens when the engine starts for the first time during the drive in HV mode; under normal HV operation, the engine turns on and off quietly.
    Has anyone else noticed this on their Primes?
    52,373
    different than the cold start sound on your last prius?
  3. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    I have noticed a similar thing;).
    And I installed an oil catch can at 21 k to collect data:)
    But here's what I found at 30k miles when I did our oil change:
    73543908-3845-4E0A-B02D-1B8453435B4D.jpeg ACF3738A-7BA8-484D-B6C8-EA6800596A89.jpeg
    So this spooge is recycling around :cool:.
    Since the engine runs less, the longer you go without running the engine, the more condensation builds. Something to consider (y).
    antiglare likes this.
