Rattling 2k miles after HG replacement.. but only after sitting 5 mins.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 462disco, Aug 15, 2025.
  1. 462disco
    462disco Junior Member
    32
    16
    Socal
    Head resurfacing, all valve stem seals replaced, hot tanked.
    I just pulled my EGR tube 4k miles after cleaning and there’s a baked on oily sheen, so she’s definitely burning oil from somewhere.
  2. Mendel Leisk
    41,467
    What's the oil consumption been like, historically?
    But yeah, you mentioned oily plugs.
  3. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,698
    1,745
    Bay Area
    I assume they lap the valves and checked if it’s all sealed?
  4. 462disco
    32
    16
    Socal
    I just changed the oil - got 4.1qt out, so it burned right under 1/2 a quart over ~4k miles. Seems insignificant for the amount of oil I’ve seen. I suspected possible leaky injector? Next oil change I’ll have to send some in for analysis, but I haven’t smelled fuel in the oil at all.
    The machine shop said they tested it, I don’t think they lapped it. I did do the “water test” and filled both intake / exhaust valves with water and let it sit overnight.. didn’t see any seeping on the combustion chamber side.
  5. BiomedO1
    BiomedO1 Senior Member
    3,631
    1,873
    SacTown, Ca
    The proper test here is a compression and leak-down test.
    The shade-tree mechanic test above will only reveal a major valve issue, since gas molecules are way smaller than water molecules. I wouldn't expect this test to fail, since a professional shop did the head - they should've already ran that test. Lapping the valves or not!
    I'm just spit-balling, because I haven't had one of those apart. Could those new head bolts be slightly out of spec.? If any of those head bolt holes bottom-out; you may think that it's torqued-down correctly.
    Oil burn is more than likely sticky piston rings, assuming the head was done correctly.
    YMMV
  6. 462disco
    32
    16
    Socal
    The final headbolt spec IIRC was in degrees, I went with FelPro headbolts & cleaned/blew out all the holes beforehand, they all went in without issue, but I suppose it’s a possibility.
    Just did a piston soak with b12 and ordered a leakdown tester. After testing & reassembly I’ll run it for a couple thousand miles and recheck the plugs for oil. I agree - leaning toward sticky rings that could possibly be causing my issues.
    BiomedO1 likes this.
  7. ASRDogman
    ASRDogman Senior Member
    7,598
    3,916
    Water is too thick. If it leaked through, then you have a large gap.
    Use wd40 or other light oil, it's very thin and any gap, it will leak through quickly.
    I did do the “water test” and filled both intake / exhaust valves with water and let it sit overnight.. didn’t see any seeping on the combustion chamber side.[/QUOTE]
