Rattling noise from rear suspension
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by altdel, Oct 17, 2016.
  1. altdel
    altdel Member
    70
    36
    Danville, CA
    I start noticing a somewhat loud rattling noise from the right rear last Friday. It sounded like something was loose and was flapping around as the car was moving. I emptied everything from the trunk and backseat but the noise was still there. After some online searches for suspension noise, I was able to reproduce the problem. When I bounced the rear bumper up and down, I could hear a clear click-click noise coming from the rear suspension area.
    I took the car to the dealer to have it checked this morning. This afternoon they called me back to say that they have identified the problem, but didn't have the parts to fix it. They ordered the parts, which will there in the morning, and I had to leave the car overnight. I'm interested to see what parts got replaced.
    I had a Gen 2 (2006) Prius for 10 years, with 200K miles when I sold it. The only thing I had to replace was a water pump after more than 100K miles. My current Gen 4 Prius 2 is 8 months old with 16K miles on it, but I'm already facing two safety recalls... and this.
    Shaunius, Rangerdavid, tucatz and 2 others like this.
    49,693
    i know, toyota quality is loosing it's luster. i wonder if it's because of the new direction they have undertaken with akio toyoda.
    RCO likes this.
  3. altdel
    altdel Member
    70
    36
    Danville, CA
    I picked up my car this morning. It turned out that the problem was the top nut on the right rear shock was loose.
    There is even a TSB for it (TSB 0144-16). They replaced the top nut on both rear shocks and the noise is gone.
  4. frankemtp1
    frankemtp1 Junior Member
    US
    Four Touring
    I had a similar problem with my Gen 4 T4 and a torque wrench and a bit of knowledge fixed it. It took 2 trips to the dealer but all quiet now.
    RCO likes this.
  5. altdel
    altdel Member
    70
    36
    Danville, CA
    The "top nut" replaced has a Toyota parts number of 94130-61200.
    It's the parts marked "10" in the drawing.
  6. Mendel Leisk
    38,873
    Is that 3rd gen rear suspension, solid rear beam?
  7. altdel
    altdel Member
    70
    36
    Danville, CA
    That drawing is from the parts vendor's website and is not specific to Gen4's double-wishbone rear suspension.
    The top nut fits Prius's rear shocks from model year 2012 to 2016, according to the website info.
    The Gen4's double-wishbone looks like this:
  8. Mendel Leisk
    38,873
    Yeah, that's what I was thinking: different pic but right part. :)
    Josem3 and Alexander santiago like this.
  9. Anastaceyrose
    Anastaceyrose Member
    60
    66
    I took mine in about 3 months ago and they fixed the same exact part. I had the same rattling too.
  10. altdel
    altdel Member
    70
    36
    Danville, CA
    Wow, it's more wide-spread than I thought. I wish they had made the double wishbone more reliable :)
    Alexander santiago and RCO like this.
  11. exstudent
    exstudent Senior Member
    2,214
    901
    Torrance, CA
    The design is fine.
    The top nut on the rear shock was likely not torqued enough:
    1) with a regular nut.
    2) with a one time use lock nut.
    I bet they replaced the top nut with a lock nut (inside contains plastic that gets threaded when tightened, and is to be used once).
    Josem3 likes this.
  12. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    Not torqued right during factory assembly??? You think?
  13. exstudent
    2,214
    901
    Torrance, CA
    Person on the line probably had the wrong setting, obviously low.
    Josem3 likes this.
  14. Mendel Leisk
    38,873
    Or something it's torqueing against is compressing? Or the nuts are somehow working loose? Seems a common occurrence.
  15. goldfinger
    goldfinger Active Member
    535
    402
    Buffalo
  16. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    I wonder why they wouldn't use a removable threadlocker like Loctite 243. I keep a bottle around for whenever I am reassembling screws/nuts on any of my cars, tractors, mowers, trimmers, etc. It keeps fasteners from vibrating/moving after tightening, yet can still be easily removed when necessary. (y)
    RCO likes this.
  17. krmcg
    2,592
    2,390
    Whittier, CA
  18. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    The "real" nut in this problem, is the assembly line worker who doesn't give a damn about the quality of work he does. May have even left the nuts loose on purpose.
    Josem3 and Dragon Rider like this.
  19. Nick pakhnyuk
    Nick pakhnyuk Junior Member
    Portland oregon
    Those nuts and bolts tend to get lose after driving over many Bumps
  20. Coast Cruiser
    2,267
    2,571
    I've owned many cars in the past, dating back to 1972, and I've never once had a problem with "loose shock nuts." And never experienced any rattles (or failures) from the suspension parts. IMO, Toyota has gotten very sloppy in the last 10 years, and they probably don't care because they still sell a Zillion cars every year.
    Tim Jones and thatoneraccoon like this.
