Rattling noise from rear suspension
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by altdel, Oct 17, 2016.
  1. Mo. J
    Mo. J Junior Member
    Saudi Arabia
    I had the noise for more than a month now, steadily increasing. I checked the boot and the door, but there is nothing. Also if I shake the car while it is parked there is nothing! So definitely suspension problem. Took it to a mechanic yesterday, and said that the upper part of the shock is to be replaced.
    I guess I gotta try tightening the nut like (KMaletsky) before ordering any parts.
    krmcg likes this.
  2. Mendel Leisk
    41,463
    Pretty sure there's a technical service bulletin or similar for this. Check with dealership: could be free, and they know exactly what to do.
  3. Mo. J
    Mo. J Junior Member
    Saudi Arabia
    UPDATE
    Yep, took it to the mechanic, turned out it's true, the nut in the upper side is loose. Good thing he had the tools to tighten it without removing the whole shock absorber. Because removing the lower part is a nightmare.
    Now I drove +20km and no noise. I'm just afraid it will loosen again sometime. 114929_RearSuspension-1024x758.jpg
    tucatz, krmcg and Mendel Leisk like this.
  4. doctorman
    doctorman Member
    210
    35
    NY 11020
    just bought a 2016 Prius III with only 34K miles on it and noticed the squeaky noise from both back tire wheels and reproduced by shaking the car up and down by putting my weight on the each of back tires...
    the VIN in the TSB does not include my VIN, could it be the lose nut?
    JTDKARFU4G300 is in tsb
    mine is JTDKARFU4G302.....
    it is embarrassing for 34K toyota having this issue..
    would Toyota cover this for me considering the mileage ?
    any better video or picture of the nut in question?
    siegfried76 likes this.
  5. Joemcb
    Joemcb Junior Member
    Michigan
    Three Touring
  6. Joemcb
    Michigan
    Three Touring
    For everyone on this post. Thanks for giving me back my sanity. The repair as described took about 15 minutes of actual work and total time with going to get the tools from the shop in the basement was 40 min. Still steady low speed rattle, gone! Really no special skills needed other than filling the instructions here. Thanks again
    Prodigyplace likes this.
