Ray Iannuzzelli cost per mile PHP vs Volt
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by carpedal, Apr 18, 2012.
  1. carpedal
    carpedal Member
    37
    58
    Centreville, VA
    Ray Iannuzzelli cost per mile PIP vs Volt
    Mr Iannuzzelli over at GM-Volt has written an honest comparison between a plug in Prius and a Volt. The results are eye opening. For example, below 10 miles range the Prius is more efficient. Read for yourself. Volt superiority is in a narrow range of miles. For some commuters, the Volt is a wise choice. For others, not so much.
    Cost per Mile Comparison: 2012 Volt vs. 2013 Prius Plug-in
  2. Keiichi
    Keiichi Active Member
    808
    79
    Goleta
    Interesting... If you use the vehicle for longer ranges, the cost savings literally disappear at certain ranges, presuming that you do not use a charging station and fall back on the gas engine part over time.
  3. austingreen
    austingreen Senior Member
    13,574
    4,114
    Austin, TX, USA
    Re: Ray Iannuzzelli cost per mile PIP vs Volt
    Fairly good comparison, the numbers are a little screwed up, but crossovers seem about right.. I would say that narrow range is where most americans drive. IIRC the volt gets charged at an average of 27 miles. In the higher mileage area where the prius phv is more efficient, drivesr might be better off just buying a prius and choosing the options they want, electric miles are a small percentage here.
    Different choices are good. some phv drivers like john1702 seem to charge twice a day and use very little gas.
  4. kbr0125
    kbr0125 Junior Member
    32
    Western New York
    If only you could get a PIP with the same battery as the volt.
  5. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    In theory, owners would always buy the car optimized for them.
    It will be interesting if PIP owners have very short or very long commutes, where the car is superior.
  6. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    This is very interesting. I have long thought that Volt was a clear winner, because the range where it has advantage -- 16-65 miles -- is exactly where most everyone drives in a day. And this is why we read of Volt owners getting 1,000 to 5,000 and even 11,000 miles on a single tank of gas. That simply won't happen with most Plug-in Prius owners.
    But my commute is 85 miles roundtrip, and my forward-thinking employer won't provide electricity at work. So my Plug-in Prius is the most efficient choice after all.
  7. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    That assumes you pay the average price for electricity. If your electricity is cheaper than average, the range of advantage of the Volt gets larger, and vice versa. Around $0.19 / kWh, the advantage of the Volt is gone altogether.
    Of course, that also depends on price of Gasoline. A more useful chart would show when each car was a better deal based on ratio of gas / electric prices, and miles traveled.
  8. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Remember to exclude CA, where people unable to charge a PiP will buy them for the HOV lane access.
  9. bisco
    49,446
    i wonder what would change if they had the same size body/ cu. ft. capacity?
  10. Corwyn
    2,171
    659
    23
    Maine
    Right, let's try to ignore the irony that California is encouraging people to buy a car which gains its environmental improvements by being charged with electricity, while at the same time pricing electricity so high, that it is encouraging them to use it like a regular car (not charged), thus wasting the entire potential of the car...
  11. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    I think that he`s been copying my posts herein and elsewhere. I`ve been postulating this for the better part of two years now.
  12. AllenZ
    AllenZ Active Member
    640
    63
    Chicago
    Great analysis!
    However, the reliability of those two cars should be very different I guess. Look at the historical records. I would be much more comfortable on Toyota side...
