Re: 2018 Prius 1 or 2, on the highway, how is overall comfort and noise?
Discussion in 'Gen 4 Prius Main Forum' started by KAKRA, Dec 11, 2018.
  1. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    • It's a generally low-stressed vehicle;
    • Brakes barely get used - unless you're rough driver - they could well last 200,000 miles;
    • The engine runs only 60-70% of the time;
    • There is no gearbox to break-down (which can be one of the biggest problems with new cars with Twin Clutches expensive to repair if they go, or extremely complex 8 or even 10 speed Autos. And a friend just had to spend $4000+ getting her SUBARU CVT fixed - out of warranty);
    • The electric motor/generators - in the 3 yrs I've been on PriusChat, I haven't heard of a single failure, though maybe some of the really old ones have?
    • The battery is warranted for 8 or 10 years, and have been lasting well past that time - and if they then do need replacing, it's a minor cost compared with the fuel savings.
  2. alanclarkeau
    7,045
    7,592
    I ended up putting my seat almost to the top of it's adjustment as being what is most comfortable for me - I'm 5'10" and have plenty of room above my head.
  3. KAKRA
    KAKRA New Member
    22
    So. Calif'
    2018 Prius
    Thanks for the replies. I appreciate them. Boy, the more I read, the more questions come up. I'm not used to a car that thinks more than me.
    Under certain conditions, will the car not allow the use of the A/C, heater, cruise control, etc? Driving on the highway on a hot summer day (we live in So. Calif') at a fairly constant 65-70 mph, on a trip of 20 miles or more, will the car shut off the A/C? Or same driving scenario, except it's a cold day and you're running the heater, will it shut the heater off?
  4. alanclarkeau
    7,045
    7,592
    No - First the A/C. The A/C runs off the Hybrid Battery. You can even park waiting for someone under a tree with A/C blasting - keep the car running, it's silent for a good few minutes till the Battery goes low, then the engine starts up intermittently to give the Battery juice to run the A/C. Drive along in town, and it just drives like normal, pull up at a traffic light, it goes silent except for the A/C fan, and the engine won't come on unless it's a really long light or when you take off when it goes green.
    Heater - yes, it needs the engine to run to provide heat. So, cold morning, your Climate Control is set at 22C from the day before - the engine starts almost immediately and runs till the heater core is warm enough to heat you up. It then works like a normal hybrid drive.
    Cruise Control - yes, it just works. It's (I'm not in USA - so I could be wrong, but think all the US models have it now) got RADAR Cruise - so it'll sit behind a row of traffic, keeping an intelligent distance behind, speeding and slowing in sync with the car/truck in front. Wonderful - I would never go back to a car with "just" cruise control. It's not "self-driving" - nothing is - but it just helps in tight traffic. Warning - like anything automatic, it still needs carefully watching the traffic, and occasionally intervention.
    I just did 2 100km return trips a couple of days apart, 31-34C deg, RADAR Cruise 95% of both trips. 62.5MPH speed limit for 90% of the trip which is what I set the RADAR Cruise on, though the traffic was heavy at times so slowed maybe to 50 on occasions. Got 69US MPG for both return trips.
  5. padroo
    padroo Senior Member
    2,763
    2,252
    I see you are interested in the Prius, how does your son feel about it? Does he have any other cars on the list?
  6. KAKRA
    KAKRA New Member
    22
    So. Calif'
    2018 Prius
    He's mentioned the Honda Civic sedan with a 2.0L CVT. We haven't talked in detail yet as I'm 400 miles away until Christmas week. I think he's leaning quite a bit towards the Prius simply because of the better gas mileage. I lean towards the Honda but it's his choice. I must admit I'm more open to the Prius than I was before reading about it. I'm still concerned about the lack of power the Prius has. It's something I'm not used to. I'll share all I've learned and see what he thinks. Then go check one or both out.
  7. KAKRA
    KAKRA New Member
    22
    So. Calif'
    2018 Prius
    Reply #21 mentioned there's no gearbox, which I understand as meaning no transmission?
    When you build a Prius on the Toyota site, it says ECVT ("Electronic continuously variable transmission"). I'm confused, again.
  8. alanclarkeau
    7,045
    7,592
    No, no gearbox. There is a clever, but simple planetary gearset which is (simply described) driven by either (or each of) the engine or the 2 Motor/Generators (MG1 and MG2). MG2 always drives, assisted by the engine when needed - and the output goes direct from the planetary gearset to the axle drive through the clutch damper assembly. When slowing down or "braking" - which will be regeneration, the reverse happens and MG1 and MG2 charge the Hybrid Battery. The drive in reverse is only by electric motor.
    There is no belt (like a CVT), nor clutches (like a DSG etc), nor a torque converter or clutches (like a "normal" auto).
    If you have 25 mins to watch this - it shows the assembly of the planetary gearset [just check it starts at the beginning - it kept starting 10 mins in for me]
  9. alanclarkeau
    7,045
    7,592
    You said in an earlier post about "lack of power" - I've not had any time when I wished for more - but then it depends on what you're used to. Maybe go for a drive in one. Alternatively, hire one for a weekend - though, a rental car isn't necessarily representative of the breed.
    dbf likes this.
  10. bisco
    51,950
    not sure where you're getting your ideas like no heat, a/c or cruise.
    prius is a normal car in every way to the driver and passengers. there are no issues with finding something is different after you've purchased, other than the obvious things like sks, shifter knob, power button etc.
    one thing that is a bit different, prius likes to be driven. the 12v won't stand up to long periods of disuse, and the nimh hybrid battery model would not appreciate an application like a seasonal home where it sits for months at a time every year. lithium models would poly handle that better.
    alanclarkeau likes this.
  11. bisco
    51,950
    i think it's just the cheap seats. there are probably a few other low end cars with the same problem, but even a camry has better seating. gen4 is supposed to be somewhat improved, or the higher package has leather and adjustable lumbar which makes a difference.
  12. Leadfoot J. McCoalroller
    8,088
    7,569
    Pennsylvania
    2018 Prius c
    While the battery, electronics and program code dependency on a prius is far higher than other cars, consider that the actual transmission has something like 1/20th the parts count of a traditional automatic transmission. They've achieved a massive simplification in terms of lubricated parts wearing on each other.
    A certain portion of Prius owners bought the car specifically to support very long commutes and high utilization. We've got 12k miles on our 7-month old car now. You spend that long in the car, more of your aches and pains happen there.
    Getting in and out of it is less comfortable than our other cars, but the reduced fuel requirement pays big.
  13. KAKRA
    KAKRA New Member
    22
    So. Calif'
    2018 Prius
    I read a review and the guy said he was just driving along on the highway and when he tried to set the cruise control, he said either "the car wouldn't allow it" or "the display said "cruise control not available"? That got me to wondering if other things, especially power draining things like A/C, could be effected?
  14. KAKRA
    KAKRA New Member
    22
    So. Calif'
    2018 Prius
    I'm just going by what the popular car testers like Motor Trend, Car and Driver, Edmunds and others say. They all use different words to describe the Prius as under-powered. "Lack of power", "Boring", "Not fun to drive", "Need to plan if you want to pass", are some of the quotes. Personally, I have no idea. I see the Prius only makes 95 HP and weighs around 3,100 lbs so I have to wonder. That's why I'm bringing up so many things here. You know and I need to know so I can help make a good decision.
    My son's only vehicle so far is a tired old hand me down '94 Ford Ranger that now has 240,000 miles on it and has had it. A new Prius will seem like a rocket compared to what he's used to.
    I appreciate all the help. I know I sound kind of ignorant but that's part of learning about something.
  15. dbf
    dbf Member
    78
    86
    NE Ohio
    You can't set the cruise control on below 28 MPH on the Gen4 Prius, so you will get a message about it if you try. That has nothing to do with power draining of course.
  16. dbf
    dbf Member
    78
    86
    NE Ohio
    The 2018 Prius has 121 HP and is like a rocket compared to the '95 Ranger I had!
  17. bisco
    51,950
    please point us to any articles/reviews with what appears to be dubious info. it would be helpful to all concerned(y)
  18. KAKRA
    KAKRA New Member
    22
    So. Calif'
    2018 Prius
    I have another question. The 2018 Prius Two "Eco", is $500 more than the Two. It gets about 4 more MPG which will get you your money back if you go enough miles. From what I see the only major difference is the battery is a Lithium-Ion instead of the NIMH.
    Am I right that the Lithium is the "over-all" superior battery? I know for 2019 the NIMH will be used only in the AWD models because Toyota is assuming the car will spend a lot of time in cold climates. My son doesn't plan on spending a lot of time in colder climates anyway. I know a lot of you have learned a lot about batteries since owning a Prius. Which battery would you prefer and would you agree the Two "Eco" is the smartest buy?
  19. KAKRA
    KAKRA New Member
    22
    So. Calif'
    2018 Prius
    I'm sorry. I remembered the Toyota site saying the 1.8L made 95 HP but when combined with the electric motor it's 121.
  20. bisco
    51,950
    i prefer the lithium, but nimh is the proven. i have had both, and there isn't much difference in performance.
