Re-hydrating the battery modules.
Discussion in 'Gen 2 Prius Technical Discussion' started by Britprius, May 6, 2015.
  1. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    I did tell you it would get hot. Surprising isn't it.
    John
  2. a_triant
    a_triant Member
    83
    33
    Earth
    #182 a_triant, May 30, 2015
    strawbrad and Britprius like this.
  3. a_triant
    a_triant Member
    83
    33
    Earth
    Finally received all the items, and started the re-hydration!
    i will update this post as will have something new.
    The first what i did is cut the length of drill bit to make it short enough to not touch the plates of module!
    The drill bits that i used have diameter 1.2mm
    As marks for holes i used the letter on the modules, you can see in the photo below, the inject hole will be above letters "es" of word gases and the middle drain hole will be near the Japanese letter
    After when complete with holes i weighted all the modules
    #1 1032
    #2 1037
    #3 1032
    #4 1032
    #5 1035
    #6 1037
    #7 1034
    #8 1037
    #9 1036
    #10 1035
    #11 1033
    #12 1035
    #13 1029
    #14 1035
    #15 1034
    #16 1034
    #17 1035
    #18 1035
    #19 1032
    #20 1033
    #21 1031
    #22 1033
    #23 1033
    #24 1029
    #25 1033
    #26 1034
    #27 1033
    #28 1033
    #29 1031
    #30 1029
    #31 1034
    #32 1037
    #33 1036
    #34 1035
    #35 1034
    #36 1034
    #37 1035
    #38 1038
    #39 1037
    #40 1037
    Here my capacity to compare
    #1 5212
    #2 4939
    #3 3844
    #4 3704
    #5 3983
    #6 3513
    #7 3277
    #8 3045
    #9 2084
    #10 2223
    #11 1939
    #12 1908
    #13 1643
    #14 1468
    #15 1616
    #16 1200
    #17 1279
    #18 1217
    #19 1209
    #20 1066
    #21 1510
    #22 1028
    #23 1290
    #24 1245
    #25 1686
    #26 1611
    #27 1695
    #28 1589
    #29 1845
    #30 1638
    #31 1807
    #32 2322
    #33 2448
    #34 2469
    #35 2405
    #36 2672
    #37 3488
    #38 3696
    #39 4442
    #40 4989
    Now preparing for injection, and same i did to the needle, i left it length about 6mm
    Mixed all the KOH that i have left that's about in 400grams, in a 2Lt de-mineralized water
    injected the first four, as John said with a edge risen about 2inch(5cm), now i will leave them 30 minutes vertical and after 30 minutes horizontal without but without edge risen, and then will weight them again
    Later injected all the other modules so they will have a lot of time to soak of the mixture
    During injection i discovered that the mixture can be injected even fast as 20ml in 15sec! that's mean the liquid can travel very fast between cells
    After many cycles i did not seen any results in recovery, i suspect in my case is corrosion of electrode or electrode deterioration, and looks like in that case is impossible to restore the modules :(
    tapping thread & sealing
    After tapping threads i added some silicone for better sealant
    I suspect i damaged the threads on first few modules by turning the screws more than needed, will hope they are okay...
    Alex.
    #183 a_triant, Jun 3, 2015
    nh7o and strawbrad like this.
  4. Britprius
    5,194
    1,921
    You can leave the hole as it is, and fill the module on the final fill very slowly. The only reason I offset the fill hole was to make filling faster. The drain hole is the important hole as this sets the level in the cells.
    John
    a_triant likes this.
  5. a_triant
    a_triant Member
    83
    33
    Earth
    I don't know maybe i injected too fast, i tried slowly but after a 5ml it started going out from injection hole i waited and tried again and same happened, then i pushed the needle very tight and injected faster until it go out from drain hole :D
    Now i will leave them vertical 30 minutes after horizontal 30 minutes and then will try inject again but without risen edge, after will weight them again! to see how much injected in every module, i picked a strongest and weakest modules (5Ah-1Ah)
    Alex.
    strawbrad likes this.
  6. Britprius
    5,194
    1,921
    Did you raise the fill end of the module about 2 inches (50mm) before trying to fill?
    John
  7. a_triant
    a_triant Member
    83
    33
    Earth
    #187 a_triant, Jun 3, 2015
  8. Britprius
    5,194
    1,921
    It took me about 1 to 1.5 minutes to inject 20ml so about 4 minutes to inject 60ml.
    John
  9. a_triant
    a_triant Member
    83
    33
    Earth
    #189 a_triant, Jun 3, 2015
  10. Britprius
    5,194
    1,921
    In the picture you have the fill hole at the bottom it should be at the top. So turn the module over.
    John
  11. a_triant
    a_triant Member
    83
    33
    Earth
    #191 a_triant, Jun 3, 2015
  12. a_triant
    a_triant Member
    83
    33
    Earth
    #192 a_triant, Jun 4, 2015
  13. strawbrad
    953
    1,007
    Hi Alex,
    Have you made any more progress? I have a couple of suggestions to help speed things up. Do not add more charge than 1 1/2 to twice the discharge. After a 1400 mAh discharge any charge more than 2100 mAh is just going to heat and boiling off the electrolyte. A charge of 2800 mAh would give plenty of cushion to ensure that the module is fully charged. The amount of charge can be increased as you see the discharge increase. Discharging at 0.7 A is painfully slow. Set up a headlight for discharge. Time from full to 6.0 volts and watch for the time to increase with each cycle. Do not go below 6.0 volts. These changes could reduce a cycle from about 5 hours to just one hour.
    Some modules can not be saved by re-hydrating. Two good examples are the first Gen that I sawed the top off and the second Gen module that I put screws in to measure each cell voltage. Both of the modules had weak cells that suffered from self discharge and maybe cell reversal. I will not reuse any module that can not hold at over 7 volts in long term storage. Have any of your modules fallen below 7 volts just from sitting unused?
    Brad
  14. a_triant
    a_triant Member
    83
    33
    Earth
    #194 a_triant, Jun 6, 2015
  15. a_triant
    a_triant Member
    83
    33
    Earth
    Did about 7 cycles with stoping the charge by delta peak, and still zero improvement... almost lost all my hopes :confused: have one last idea, to cycle until they loose the weight to original then may add little water again and try again to cycle, to do this faster i may set them charging all the day without capacity cut-off at low current to make them heat a lot, if still nothing then will refill them again and will place the battery pack back to the car maybe there will happen something, the car will cycle all the pack al lot faster...
    I also have thoughts that may they not improved at all, before when i cycled them i charged at 0.7A the maximum voltage that they reached then was about 8.7-8.8, now at 3A they reaching 9.05-9.20, so maybe from here are the extra mAh that i got? i'll try at end again charge at 0.7A
    I don't understand how you recovered them from few cycles :confused:
    Here some measurements maybe will be useful
    From outside top to the plates is about 17.5mm
    The thickness of plastic is about 2.2mm, i got screws length 5mm according to previous measurements that Roy did, he said is 4.4mm :coffee::D
    Alex.
    #195 a_triant, Jun 7, 2015
    royfrontenac likes this.
  16. royfrontenac
    royfrontenac Active Member
    247
    100
    Kingston Ontario Canada
    2001 Prius
    Hi Alex - you have very good pictures and filling and testing data congratulations.
    You were wondering how others were able to get better discharge readings. I have found modules that test in the very low ( 1000 mah to 2000mah) to be not usable and I do not use them. To combine a 1Ah with a 5 Ah will cause the code 3006 to come up when you put the assembled battery in your car as I have tried that with modules much closer in capacity. The 1 Ah will have a lower voltage on heavy current loads then the rest and cause the 3006 code.
    The modules I filled were done in the car and a little solution boiled out of them under testing - this brought up the code 3009 (ground on battery). I removed all modules and cleaned them reinstalled and code did not come back.
    The code 3006 (unbalanced module pairs) is still coming up once in a while on my re-hydrated battery and I have been driving it over a week now. The minivic shows on freeze fame that a week module group still exists but is getting better as time goes on.
    Note - all the modules in the battery modules I re-hydrated in the car tested around 5500 mah dry before being installed in the car, each took about 3 cycles to get to 5500 discharge.
    However- about a year ago I did recycle some gen 1 modules (dry) and their discharge numbers were between 3000 and 4000 mah and they worked out OK and are still running to-day with no codes. Note - at the beginning I kept getting code 3006 and just keep resetting the code and running the car gently.
    #196 royfrontenac, Jun 7, 2015
    strawbrad and a_triant like this.
  17. a_triant
    a_triant Member
    83
    33
    Earth
    #197 a_triant, Jun 7, 2015
  18. royfrontenac
    247
    100
    2001 Prius
    Alex - I did not know the information about up to 97 cycles and they improve - I probably threw out modules that could have recovered. It will be interesting to let me know know if you pair 1Ah with 5Ah and battery works OK.
    The DTC POA7F is a code that does not come up with the minivic but it appears to be saying the the samething unbalanced modules. Did the code disappear after 10000KM?
    You indicate that the middle modules see more load, but the cells are all in series so they see the same load currents - however the middle modules get hotter then the outside modules and thus may deteriorate faster.
  19. a_triant
    a_triant Member
    83
    33
    Earth
    #199 a_triant, Jun 7, 2015
  20. strawbrad
    953
    1,007
    Hi Alex,
    Have you been running these modules in your car for the last two months? Or, have they been sitting unused for the last two months since your last charge cycle? It is a big difference as a car will keep the modules charged. Your very low capacity modules likely have a cell that self discharged and reverse charged. Re-hydration has not been shown to fix self discharge or cell reversal. I will not use any module that can not hold at over 7 volts indefinitely. They just do not work well. I tested the 5 good cells of my topless Gen I module at over 6 Ahr. If I had run the test including the bad cell the results would be much lower.
    Brad
