Re-hydrating the battery modules.
Discussion in 'Gen 2 Prius Technical Discussion' started by Britprius, May 6, 2015.
  1. Ancel Bhagwandeen
    Ancel Bhagwandeen Junior Member
    47
    40
    Caribbean
    gdanner likes this.
  2. tracy ing
    tracy ing Active Member
    384
    173
    wash dc
    Its acceptable to me because it is a normal part of the process to recondition the modules at 6.5 ah to delta voltage end of charge
    What are my real world results on the modules I have fixed over the past decade
    Astounding , and still in service.
    Here's the latest pack I worked on for a few days, modules are all from one 2008 and are almost ready to be installed in another 2008 that has hv issues.
    docs.google.com/spreadsheets/d/e/2PACX-1vSx-WW7K8mTj9YxoQQauVHKokyvHNWENl7WH8VD_i-Z5Fano87mN5itP7M-acQUpMnqNuMlrNzj9sS7/pub?output=pdf
    Also, that discharge to 3 volts, only ever did it on this pack, wont ever do it to another cell, did nothing beneficial
    #382 tracy ing, Jun 23, 2022
    Ancel Bhagwandeen likes this.
  3. tracy ing
    384
    173
    wash dc
    Maybe
    I am charging to delta voltage end of charge, which is prolonged voltage at say 8.85 to almost 9 volts for several minutes until the voltage starts dropping due to saturation
    I place a cut off q tip wrapped in plastic into the vent, then, using a sharpy to provide a balance point, place a can of beans on top to help prevent the qtip from rising up and leaking.
    Nothing bad has ever happened, and none of my end of charge gases are lost.
  4. Ancel Bhagwandeen
    47
    40
    Caribbean
    I use Delta Temperature as the end point with a current throttle to 1.5A charge rate as the blade passes over 8V. 3.0A under 8V.
    Usually the charge terminates at around 42°C with an ambient of 30°C. I have 3 temperature sensors array across the blade. Centre temp. is always about 4 to 5° more than the ends. My custom gear handles the charge/discharge (up to 16A) and the # of cycles while tracking the AH in, Discharge AH out, and internal resistance & Voltage and times.
    gdanner likes this.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,092
    Columbia, SC
    Because Panasonic/Primearth/Toyota don't have enough experience or invest enough in R&D to know what they're doing............unlike the rest of us battery scientists in this thread. Maybe they just figure the tops will blow off if it gets bad enough.
  6. Ancel Bhagwandeen
    47
    40
    Caribbean
    Thanks for sharing that pdf on your reconditioning data set. Would have liked to have seen the internal resistance outcomes as well for pack balancing.
  7. tracy ing
    384
    173
    wash dc
    I use 6.5 amps up and down, discharge to 6 volts (why 6.5? anything less takes longer and 6.5 is 1C and thats just fine for these modules)
    I use a fan if the ambient temp is 85 or higher, otherwise, no fan cooling i never see any heat from the modules.
    In Jan 2015 I paid 1,000 for a 2005 and got a trailer and hauled it back to virginia from nyc, it had 142,000 miles on it, a month later it had one of my packs in it using my rebuild methods car.jpg reg.jpg odo.jpg .
    My wife drove and abused that car for years with a long commute and no oil in the engine constantly
    I have been using the car a year now.
    It still has the pack from 2015 in it, it has 279,673 miles on it, the only codes we ever had were for the trans when a fuse under the hood was taken out by road salt. The pack is still running today with no issues or codes.
    That pack is the original 2005 cells with a few replacements in it, I dont recall how many but one day I will pull it out and then I will know.
    It went 142k with the factory pack, the I bought it, so far it has gone another 137,455 with mostly the same pack after i rebuilt it in 2015
    Also of note, in 2015 I did not have my fancy NIMH charger, instead I used a VECTOR 12 volt lead acid battery charger and a meter to find end of charge, that charger had 2 6 10 amp charging, I used 6 amp using that charger, it worked just fine.
    Why did I get a fancy NIMH charger, cause you have no idea how much time it takes to watch a pack using a meter for eoc instead of using the right charger that sees it and shuts down automatically lol
    People can question me about my charge rates, pack swelling and on and on
    The car above proves what I do works, and it is prius number 4
    #387 tracy ing, Jun 23, 2022
  8. Ancel Bhagwandeen
    47
    40
    Caribbean
    I dchg down to abt 5V with a throttled Dchg rate as low as 0.3A as the voltage drops. I write the code for my charge/dcharge gear so i can customize the charge/discharge profile based on temperature, Voltage, current, time and Int R. Make it all automatic.
  9. tracy ing
    384
    173
    wash dc
    My 2 cents, no reason to go below 6 volts.
  10. Ancel Bhagwandeen
    47
    40
    Caribbean
    Yes... it does seem so. The new gear I am designing to do the whole pack of blades at once won't waste time by discharging under 6.
  11. TMR-JWAP
    6,404
    6,092
    Columbia, SC
    This may be the most interesting thread I've read in a long time....I may have learned enough about reconditioning to feel comfortable tackling a battery myself pretty soon.
    strawbrad likes this.
  12. alftoy
    alftoy Senior Member
    1,132
    518
    Saskatchewan, Canada
    Glad that works for you.
  13. tracy ing
    384
    173
    wash dc
    I dont have a fancy resistance meter for batteries. i haven't looked for one for years but when i did they were expensive.
    I dont think the prius does REAL resistance reporting, i think it uses MATH to produce those numbers, and I have seen HEAT effect that math it produces. I have taken 19ohm modules and blocked the fan intake and they went to 30ohms real quick. heat and math.
    I may take the time to look at and post the resistance reported by TS after I install them to see what it reports on the banks.
    Are there any GOOD resistance battery meters out there now that arent a fortune that dont use math and instead send a signal through ?
    I use the graphs produced by the process to determine, yeah, that looks good, if the resistance was off the graphs voltages also would be off from module to module
    gdanner likes this.
  14. Ancel Bhagwandeen
    47
    40
    Caribbean
  15. tracy ing
    384
    173
    wash dc
  16. Ancel Bhagwandeen
    47
    40
    Caribbean
    I have 3 of em...been using them for about 5 years.
  17. tracy ing
    384
    173
    wash dc
  18. Ancel Bhagwandeen
    47
    40
    Caribbean
    Just heard the pressure vent on a blade I am processing make a loud 'pop' . No heat..31°C, Charge rate at 1.5A. V at 8.6V. Everything else normal, blade is clamped and can't swell.
  19. tracy ing
    384
    173
    wash dc
    yep, thats why i plug em up so i dont lose that precious gas lol
    also, thanks, i just ordered that meter, may be here this year sometime lol
  20. Ancel Bhagwandeen
    47
    40
    Caribbean
    Why are 3 of the Blades highlighted in red during the 4th cycle?
