Re-torque Prius drive shaft nut
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Rmartel, Apr 20, 2023.
  1. Rmartel
    Rmartel New Member
    NH
    2021 Prius
    Doing the 30,000 mile service on my friend's 2021 AWD Prius. The drive shaft nut must be re-torqued to I believe 129 #Ft. Since all previous Priuses were 2WD,I want to make sure I'm doing the right thing here. Is the nut located behind the wheel, right at the end of the axle? The other end of the shaft has 4 bolts, near the differential. If that is the correct location does anybody know what size socket it requires? Looks a little strange when I last checked it. Does it require a special socket.
  2. a2058
    a2058 Junior Member
    58
    24
    Westchester, NY
    2019 Prius
    XLE AWD-e
    The rear wheel side half shaft goes into the wheel hub via the splines and is tightened on with a single hub nut to 159 ft-lb and then staked in so I don’t think that needs to be touched. On the Toyota manual I just checked, those 4 nuts at the transmission side are 41ft-lb on those nuts on the motor/transmission side of the half shafts. In my experience on those, they are on tight, and really do not seem to loosen anyway, but worth a check in the early days. Mine are already 4 yrs old so they are rusted on pretty good there already so I don’t bother with them any more. Probably M10 with 13mm hex head is my recollection.
    #2 a2058, Apr 20, 2023
  3. Tianen Chen
    Tianen Chen Junior Member
    43
    16
    United States
    2020 Prius
    XLE AWD-e
    I have no idea what you are talking about based on pure text. Can you show some photos on the drive shaft nuts?
  4. Tianen Chen
    43
    16
    United States
    2020 Prius
    XLE AWD-e
    Fubar XIII likes this.
