Read a bit more thoroughly the owner's manual and...
Discussion in 'Gen 4 Prius Main Forum' started by pakitt, Apr 30, 2016.
  1. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Well, "opinions" aside, actual scientific tests in real traffic showed DRLs reduced collisions. So we have them.
    Yup, they aren't perfect. It's an imperfect world. ;)
  2. Mendel Leisk
    41,464
    It's strange around here: see a lot of (recently vintage) vehicles on the road, with BC plates, AND no daytime running lights. Guess they're bought Stateside. Seems to me they used to be more stringent though.
  3. JohnF
    JohnF Active Member
    497
    428
    Essex, CT
    OK, I'm confused. The light switch on my Gen 4 Model 2 ECO has 4 positions, top to bottom: ON (head & tail lights on), parking lights, AUTO, and DRL OFF. AUTO switches on what I assume to be the DRL's since there is no "DRL ON" option. Since I couldn't drive behind myself to check if the taillights are on in AUTO, I did the next best thing: I stopped, set the parking brake, got out and checked the taillights. The wavy rear lights are on in daytime when the switch is in the AUTO position. I checked the relevant section of the User's Manual and the text was vague. So for my car at least it doesn't seem possible to have taillights off when DRL's are on.
  4. Mendel Leisk
    41,464
    Does parking brake activate the brake lights? I think so.
    BTW: it kinda bugs me that the Auto position is next-in-line to Off. Auto tends to be the set-it-and-forget-it option, so why not relegate it to the end of the line, past Park and On positions?
    Our third gen switch has Auto positioned thus. Maybe I'm a luddite, but even though I have the Auto headlight option, I can't abide it, want to control when the lights are on or not. Also, it's physically impossible for me to walk away from a vehicle with the headlights blazing.
  5. JohnF
    JohnF Active Member
    497
    428
    Essex, CT
    I thought the wavy LED lights were the tail lights, not the brake lights.
  6. David Beale
    5,963
    1,989
    Edmonton Alberta
    The parking brake does not activate the brake or tail lights. It's for parking, not driving.
    The parking brake is supposed to deactivate the DRLs in Canada, but lately it seems to only work if the P-brake is on when you start the car, meaning the DRLs come on when you release the p-brake but don't go off if you apply the p-brake after the car is in "ready". I say "lately" because earlier vehicles I owned turned the DRLs off whenever the p-brake was applied (you can "trick" the system by actuating the p-brake lever only one notch and drive - the brakes aren't actuated at that low setting but the DRLs are off). That doesn't work with the Prius.
  7. JohnF
    JohnF Active Member
    497
    428
    Essex, CT
    In my US model, when I pull it into the carport and set the parking brake, the DRL's and tail lights stay on, and don't shut off when I turn off the ignition. It's a bit disconcerting, they wait a minute or more and then shut down.
  8. Tideland Prius
    16,559
    Really? In Canada, the taillights are off in AUTO.
    Funny. I actually prefer the AUTO position next to the OFF because it means it's next to the parking light switch, making it easy to go from AUTO to parking lights. It's also easy to go from AUTO to OFF if I need to (e.g. I don't want the headlights to turn on because I'm just fiddling around in the car).
    Here's a tip. If you leave the lights on in AUTO, as you walk away from the car, a second "LOCK" request (must be activated on the key fob) will turn off the lights.
    e.g.
    Scenario 1: You get out and press the LOCK button on the key fob once to lock the car. A second press will shut off the lights
    Scenario 2: You use SKS to lock the car, press the key fob LOCK button once and it'll shut off the lights.
    ETP, JohnF and Mendel Leisk like this.
  9. JohnF
    JohnF Active Member
    497
    428
    Essex, CT
    Today it occurred to me that maybe the fact that I had pulled into my fairly dark carport had something to do with my taillights being on. So today while driving down the street I did the same test: I pulled over, set the parking brake, left the car in D with the ignition on, got out, checked the wavy taillights, and this time they were OFF. Seems as though a day/night sensor (the "headlight control sensor"?) is involved??
    The manual is not explicit: "AUTO - The headlights, front position, daytime running lights (p .245) and so on turn on and off automatically (when the power switch is in ON mode)" - p.243
    The phrase "and so on" should never appear in a manual.
    ETP, Tideland Prius and Mendel Leisk like this.
  10. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,802
    1,170
    Auburdale FL
    Good thought. I kind of didn't like the rain x effect on my front window. But it sure keeps the water calcium spots off.
    alanclarkeau likes this.
  11. Hoddie
    Hoddie Member
    87
    110
    Belgium
    Can I just check something - I left the manual I printed at work, if the lights are set to AUTO does this include the rear lights also? I'm assuming the dash indicates somehow if the rear lights are on or not (if only by dimming the dash)?
    ETP likes this.
  12. JohnF
    JohnF Active Member
    497
    428
    Essex, CT
    On AUTO, the rear lights are not on in the daytime. A friend driving behind me confirmed this. I think they go on at night if it is set on AUTO.
    Hoddie and ETP like this.
  13. ETP
    2,802
    1,170
    Auburdale FL
    Wow
    I was wondering that yesterday when it was raining.
  14. Tideland Prius
    16,559
    If it's raining, at the minimum, turn on your parking lights (which will turn on the taillights). Of course, ideally (and recommended), you would turn on your low beam headlights as well for forward and rearward visibility (i.e. others can see you coming or as they approach you).
    Obviously rain falls at different rates so if it's anything other than a drizzle or light rain (2mm/hr), I'd turn on the low beams.
    Hoddie, kithmo, JohnF and 1 other person like this.
  15. ETP
    2,802
    1,170
    Auburdale FL
    Yep, great answer.
  16. Hoddie
    Hoddie Member
    87
    110
    Belgium
    Maybe it's just me but this kinda defeats the purpose of automatic lights. The wipers can be set to auto based on rainfall, but the lights can't? Seems odd. Backward, almost :)
    ETP likes this.
  17. Tideland Prius
    16,559
    Thanks. I'd like to point out that even on some cloudy days (well more like overcast where the clouds are so thick, it l
    Automatic headlights are available. They're usually not sensitive enough in factory spec for rainy days.
    ETP likes this.
  18. David Beale
    5,963
    1,989
    Edmonton Alberta
    To clarify, "auto" setting on the lights means the lights are "off" in bright sunshine (this could mean the DRLs are on - in Canada for example) so no tail lamps, "parking lights" come on when it gets "dim" outside, and then the headlamps come on when it gets "dimmer". With Pearl S (GIII) I find the lights come on in some stage even when the sun is up but not shining on the dash, so it seems pretty conservative and safe. There are two stages of "lights on", and I noticed this in the GII Pearl as well.
